  3. print pins into csv file
  • Views 1207
gangliurfic
gangliurfic 5 months ago
I want to select an instance in a schematic and then call a function to save all the pins, name, direction, signal type, net into a csv file.
Is there such a build in function in Cadence?
I have a code working for name and direction, but got stuck at signal type
Below is the part of the code i am using, name and direction works fine, but signal type returns nil, so I am getting errors for fprint.
pinname=instTerm~>term->name
pindirection=instTerm~>term->direction
pinsig=instTerm~>term~>sigType
netname=instTerm~>term~>net~>name
fprintf(myPort "\n%s\t%s\t%s\t%s" pinname pindirection "not working yet" netname)
How can this be fixed?
Thanks!
  • gangliurfic
    I figured out one way that works.
    pinsig=instTerm~>term~>net~>sigType
  • gangliurfic
    For some reason, I can't create new post in this forum. even when I reply a post, it says something went wrong and I need to contact the administor.
    I am sorry to reply here, but this is the only thing I can do to draw your attention.
    I don't know if it is just my problem or it is a server problem.
    Please help.
    Thank you!
