  3. Lock icon appears when SKILL PCell is loaded
  • Subscribers 150
  • Views 1714
thiruvenkata
thiruvenkata 4 months ago
Hi All,
I noticed something new while creating PCells using SKILL. Whenever I load the SKILL PCell, a user lock icon appears in the view type section. The only way I can get rid of it is by opening and closing the supermaster cellview.
I am currently using the pcCellView variable in my PCell development. Is there an internal variable or a proper method to automatically close the PCell cellview after it opens, creates the required geometries, and finishes processing?
I cannot attach screenshot for some reason, so I'll share the screenshot using image hosting:
    Andrew Beckett 4 months ago
    Ah, I think you must have just deleted your second post (without the image) as my reply vanished as I was typing it.
    You can use:
    cv=pcDefinePCell(...
    dbClose(cv)
    Using pcCellView won't help as this is the cellView of the subMaster (not the superMaster) and it's only set within the body of the pcDefinePCell.
  • thiruvenkata
    thiruvenkata 4 months ago in reply to Andrew Beckett
    Thanks for the insight. I referred to the article Introduction to SKILL PCell Programming. In that article, the PCell examples show the use of the pcCellView variable inside the body of pcDefinePCell, so I was following that approach. Are those examples incorrect?
    I am sorry for the inconvenience caused by deleting the earlier post.
    Andrew Beckett 4 months ago in reply to thiruvenkata
    No, those examples are correct. All the usage of pcCellView in that article is within the body of the pcDefinePCell. The body is the code that will be evaluated to generate each subMaster when a variant is created. Closing the variant makes no sense, and you can't access pcCellView outside of the pcDefinePCell.
  • thiruvenkata
    So I assume the behaviour of getting lock icon after loading PCell code is normal and safe to ignore?
    This is because pcDefinePCell() returns the dbId of the superMaster it just created. Because it is (obviously) open for edit (since it just created it), returning the dbId causes it to remain locked. If you don't want that, you can simply close the cellView as I showed earlier in the thread.
    Whether it bothers you that it's locked rather depends on whether you need somebody else to be able to update the superMaster.
  • thiruvenkata
    Thanks for the clarification! Understood the concept.
