  3. Lock icon appears when SKILL PCell is loaded
  • Subscribers 148
  • Views 23
thiruvenkata
thiruvenkata 1 hour ago
Hi All,
I noticed something new while creating PCells using SKILL. Whenever I load the SKILL PCell, a user lock icon appears in the view type section. The only way I can get rid of it is by opening and closing the supermaster cellview.
I am currently using the pcCellView variable in my PCell development. Is there an internal variable or a proper method to automatically close the PCell cellview after it opens, creates the required geometries, and finishes processing?
I cannot attach screenshot for some reason, so I'll share the screenshot using image hosting:
    Andrew Beckett 52 minutes ago
    Ah, I think you must have just deleted your second post (without the image) as my reply vanished as I was typing it.
    You can use:
    cv=pcDefinePCell(...
    dbClose(cv)
    Using pcCellView won't help as this is the cellView of the subMaster (not the superMaster) and it's only set within the body of the pcDefinePCell.
  • thiruvenkata
    thiruvenkata 10 minutes ago in reply to Andrew Beckett
    Thanks for the insight. I referred to the article Introduction to SKILL PCell Programming. In that article, the PCell examples show the use of the pcCellView variable inside the body of pcDefinePCell, so I was following that approach. Are those examples incorrect?
    I am sorry for the inconvenience caused by deleting the earlier post.
