  3. Is there any callback feature for layout that triggers any...
  • Views 636
Is there any callback feature for layout that triggers any property change for instance?
MM20260514770
MM20260514770 4 months ago
I am trying to port some in house script from TCL to skill for virtuoso. I am unable to find any callback code for layout that could perform following task.
For example, let's say I have an instance and a track region is fully covering it. Is there any callback that will trigger when that particular instance has any change of property for example origin change, or row/col number changed for mosaic?
In TCL there was a callback available which will pass the modified instance object and I can filter out if the cell name matches and then my fuction could extend/shrink or shift the track region so that it still fully covers the instance.
Tanvir
    Andrew Beckett 4 months ago
    Hi Tanvir,
    Please contact customer support about this (use the Cases menu at the top to create a case after logging in). Then we can understand better your requirements.
