  3. Automatization of Maestro view and schematic (testbench...
  • Views 674
Automatization of Maestro view and schematic (testbench) for simulation of multiple results
OG202503213520
OG202503213520 3 months ago
I have a design that I need to verify and do the simulation , to give an idea , it had multiple inputs and outputs and they depend on internal values. I need to simulate each input with different output to see the delay.
Is there a way by which I can automatize the changing of equations in maestro setup depending on the inputs and outputs? Also , depending in the inputs and outputs selected , I need to automatically make changes in the testbench.
For the moment I think using "skillbrigde" (skill functions using python) the generation of schematic can be done writing a code , but I dont understand how I can make the link with maestro testbench.
If you have any solutions , please let me know.
Thank you.
    Andrew Beckett 3 months ago
    I can't answer anything on "skillbridge", but there are plenty of SKILL functions to do both schematic creation (with sch and db prefix and also maestro view creation/modification (mae prefix).
  • OG202503213520
    OG202503213520 3 months ago in reply to Andrew Beckett
    Thank you very much Andrew !
