  3. How can a concatenated string be transformed into a variable...
  • Replies 8
  • Subscribers 150
  • Views 1114
How can a concatenated string be transformed into a variable name?
SZ20260803361
SZ20260803361 2 months ago
I want to set a variable name that can change over time. For example:
item=""
lists=setof(i parseString(getCurrentTime() "") i!) =" "&&i! =":")
foreach(elem lists
item=strcat(item elem)
I received the item with the code "Aug201706212026".
I want to replace the "item" in the variable name "a_item" with "Aug201706212026", so that the final variable name becomes "a_Aug201706212026". How can I do this? I tried using `setq(stringToSymbol(strcat("a_" item)) 5)`, but this caused an error. How should I proceed?
    Andrew Beckett 2 months ago +1
    This is almost certainly not what you want to do, because creating different variable names on the fly usually means you should be creating a different data structure - e.g. a hash table indexed by the…
    This is almost certainly not what you want to do, because creating different variable names on the fly usually means you should be creating a different data structure - e.g. a hash table indexed by the date rather than a unique variable name. However, if you really want to do this (the wrong way in my opinion), then taking your code:
    item=""
    lists=setof(i parseString(getCurrentTime() "") i!=" " && i!=":")
    foreach(elem lists
    (I assume you used some kind of optical character recognition because it had some spurious parentheses) then you could do:
    set(concat("a_" item) 5)
    you can retrieve it with:
    symeval(concat("a_" item))
    A cleaner (more efficient in terms of creating garbage that needs collecting) way of building the variable name would be to do:
    cleanup=pcreCompile("[ :]")
    varName=concat("a_" pcreReplace(cleanup getCurrentTime() "" 0))
    However, if you creating a number of these, I'd use a hash table (using makeTable) as I mentioned before.
  • SZ20260803361
    SZ20260803361 2 months ago in reply to Andrew Beckett
    Dear Mr. Beckett,
    Thank you very much for your prompt, professional and informative replies. I have tried both of your proposed methods, and both work as I expected. I will test the hash‑table approach you suggested later. I will elaborate on why I require dynamic variable names based on a small ongoing project I am developing, and seek your advice on the issues I have encountered during development.
    Best regards,
    Steve
  • SZ20260803361
    This project is developed to meet requirements from the layout team. They need a persistently‑pinned UI panel that can be activated by clicks at any time. For this purpose, I planned to use dockWindow so that the panel can be docked inside the PTE frame. However, I have run into multiple issues during development, as listed below:
    1. With my current implementation, the dock window is only created for a single session window. My expectation is to make this dock window available for multiple session windows simultaneously.
    2. How can I completely delete an appForm from memory? I create an appForm via hiCreateLayoutForm, then construct the dock window with:
    dock_W = hiCreateDockWindow(
                           ?appType "layout"
                           ?widgetType "form"
                           ?form appForm )
    Afterwards I render the dock window with:
    foreach( n ns hiDockWindow( ?window dock_W ?session n ) )
    My intention is to automatically unset the global variable appForm after the dock window is generated. When creating the dock window for another session window, I would recreate the global appForm variable.
    1. If fully destroying appForm is not feasible, I considered generating time‑dependent unique variable names. Each time a new session window opens, a brand‑new global variable such as appForm_currentTime would be generated to avoid naming conflicts caused by re‑using the same variable appForm.
    This is the motivation behind my post.
    There are three global variables in my codebase: appForm, layoutForm_pte and dock_W.
  • SZ20260803361
    Source code is shown below
    load_form.il:
    (let (load_en reload_en)
    procedure(load_form()
    cond(
    (dock_W
    load_en = nil
    reload_en = t
    (t
    load_en = t
    reload_en = nil
    layoutForm_pte~>loadpte_button~>enabled = load_en
    layoutForm_pte~>reloadpte_button~>enabled = reload_en
    hiDisplayForm('layoutForm_pte)
    load_procedure.il:
    (let (a b ns)
    procedure(loadpte(a)
    load("test_layout_demand.il")
    hiFormClose(a)
    layoutForm_pte~>loadpte_button~>enabled = nil
    layoutForm_pte~>reloadpte_button~>enabled = t
    procedure(reloadpte(a)
    b=hiDockWindow(
    ?window dock_W
    if(b==t then
    hiFormClose(a)
    else
    dock_W=hiCreateDockWindow(
    ?appType "layout"
    ?widgetType "form"
    ?form appForm
    ns=hiGetWindowList('session)
    foreach( n ns
    hiDockWindow(
    ?window dock_W
    ?session n
    gui_contain.il:
    (let (load_en reload_en loadpte_button reloadpte_button loadpte reloadpte boxLayout_ver )
    dock_W = nil
    load_en = t
    reload_en = nil
    loadpte_button = hiCreateButton(
    ?name 'loadpte_button
    ?buttonText "Press this button for initial loading:"
    ?callback "loadpte(layoutForm_pte)"
    ?enabled load_en
    reloadpte_button = hiCreateButton(
    ?name 'reloadpte_button
    ?buttonText "Click to Reload: "
    ?callback "reloadpte(layoutForm_pte)"
    ?enabled reload_en
    boxLayout_ver = hiCreateVerticalBoxLayout(
    'boxLayout_ver
    ?items list(loadpte_button reloadpte_button)
    layoutForm_pte = hiCreateLayoutForm(
    'layoutForm_pte "LOAD PTE" boxLayout_ver
    test_layout_demand.il:
    (let (addMosW_string addMosW_button gridLayout boxLayout loadpte_button reloadpte_button boxLayout_ver ns)
    addMosW_string = hiCreateStringField(
    ?name 'addMosW_string
    ?prompt "M1_width: "
    ?defValue "1.5"
    addMosW_button = hiCreateButton(
    ?name 'addMosW_button
    ?buttonText "apply"
    ?callback "(AddMosM1)"
    gridLayout = hiCreateGridLayout( 'gridLayout
    ?items (list
    list( addMosW_string 'row 0 'col 0 )
    list( addMosW_button 'row 0 'col 1 )
    list( 'col_stretch 0 1)
    list( 'col_stretch 1 0)
    boxLayout = hiCreateHorizontalBoxLayout(
    'boxLayout
    ?items list(gridLayout)
    appForm = hiCreateLayoutForm(
    'appForm "LAYOUT_PTE" boxLayout
    procedure(AddMosM1()
    let((cv objs metal1 temp temp1 shapes x y ux uy xy row column transform M1_width)
    M1_width = evalstring(appForm~>addMosW_string~>value)
    cv = geGetEditCellView()
    objs = geGetSelSet()
    foreach(obj objs
    transform = nil
    if(obj~>objType == "inst" then transform = list(obj~>transform));end if
    if(obj~>objType == "mosaic" then
    x = xCoord(obj~>xy)
    y = yCoord(obj~>xy)
    ux = obj~>uX
    uy = obj~>uY
    row = obj~>rows
    column = obj~>columns
    for(a 0 row-1
    for(b 0 column-1
    case(car(obj~>tileArray)
    ("R0" || "MXR90" xy = list(x+a*ux : y+b*uy))
    ("R90" || "MY" xy = list(x-a*ux : y+b*uy))
    ("R0" || "MXR90" xy = list(x+a*ux : y-b*uy))
    ("R0" || "MXR90" xy = list(x-a*ux : y-b*uy))
    );end case
    transform = append1(transform list(car(xy) car(obj~>tileArray) 1.0))
    );end for
    );enf for
    );end if
    shapes = obj~>master~>shapes
    foreach(shape shapes
    if(car(shape~>lpp) == "M1" && cadr(shape~>lpp) == "drawing"
    then
    foreach(trans transform
    metal1 = dbCopyFig(shape cv trans)
    temp = leConvertPolygonToPath(metal1)
    temp~>width = M1_width
    );foreach
    );if
    );foreach
    );foreach
    );let
    );proc
    ?appType "layout"
    ?widgetType "form"
    ?form appForm
    foreach( n ns
    hiDockWindow(
    ?window dock_W
    ?session n
    Andrew Beckett 2 months ago in reply to SZ20260803361
    I reformatted the code to make it easier to understand (without the indentation it's nigh on impossible):
    load_form.il
        cond(
          (dock_W
            load_en = nil
            reload_en = t
          (t
            load_en = t
            reload_en = nil
    load_procedure.il
    (let (a b ns)
        hiFormClose(a)
        b=hiDockWindow(
          ?window dock_W
        if(b==t then
          hiFormClose(a)
        else
    	?appType "layout"
    	?widgetType "form"
    	?form appForm
          foreach( n ns
    	hiDockWindow(
    	  ?window dock_W
    	  ?session n
    gui_contain.il
      dock_W = nil
      load_en = t
      reload_en = nil
        ?enabled load_en
        ?enabled reload_en
        'boxLayout_ver
        ?defValue "1.5"
        ?buttonText "apply"
        ?items (list
        'boxLayout
          foreach(obj objs
            transform = nil
              x = xCoord(obj~>xy)
              y = yCoord(obj~>xy)
              ux = obj~>uX
              uy = obj~>uY
              row = obj~>rows
              for(a 0 row-1
                for(b 0 column-1
                  );end case
                );end for
              );enf for
            );end if
              ; Andrew changed M1 to Metal1 for testing
              if(car(shape~>lpp) == "Metal1" && cadr(shape~>lpp) == "drawing"
                then
                  );foreach
              );if
            );foreach
          );foreach
        );let
      );proc
        ?appType "layout"
        ?widgetType "form"
        ?form appForm
      foreach( n ns
        hiDockWindow(
          ?window dock_W
          ?session n
    My first observations are:
    1. You are using SKILL (not SKILL++) and have procedures defined within lets. These are not lexically scoped, and hence any variables they reference in a surrounding let are actually not local - they are global. This makes the code confusing and almost certainly is not doing what you think it's doing. SKILL++ mode (having the files with a .ils suffix) does introduce lexical scoping but then the procedures would be local (and you'd need to use globalProc to make them visible from outside) - but then some of the form variables wouldn't work.
    2. You will need a separate dock window for each session window, but you don't need to store that in a global variable
    3. You will need separate global variables for each form. Each (independent) form needs to have a unique global variable to represent it - you can't just re-use the same variable after constructing it (the reason is that the name needs to be known so that SKILL expressions can be generated as you interact with the form - you'll see these in the replay). You can use gensym() to create a unique symbol each time
    Anyway, I'll restructure your code a little to tidy things up and show how this can be done. This will take me a little while to clean up what you've done... I'll be back soon!
  • SZ20260803361
    Thank you very much. I will take some time to go through this and get my head around it.
    OK, here's the new code. This copes with multiple windows and (slightly) alters the initial form so that you can force the dock windows to be recreated (you may or may not want this). I've added AB comments in various places to try to explain the key differences (but there may be subtle differences here and there that I've glossed over; hopefully they are obvious though).
    BTW, you should really use a prefix for your functions to avoid clashing with others - AddMosM1 is not that unique... (the new functions I added also didn't have prefixes - I left that as an exercise for you).
    load_form.il
    ; AB: removed the local vars which weren't local
      layoutForm_pte~>loadpte_button~>enabled = t
    load_procedure.il
    ; AB: completely rewrote. Don't really need a reload, but
    ; in case you need it, added an optional argument to force
    ; recreation of the dock window and form
    procedure(loadpte(form @optional force_recreate)
      let((sess_win_list dock_W)
        hiFormClose(form)
        sess_win_list=hiGetWindowList('session)
        foreach( sess_win sess_win_list
          dock_W=sess_win~>myDockWin
          if(dock_W && !force_recreate then
            hiDockWindow(
              ?window dock_W
              ?session sess_win
          else
            ; need to ensure that if there was an existing dock window
            ; we close it otherwise you'll end up with more than one!
            when(dock_W
              hiCloseWindow(dock_W)
            CreateDockWinForm(sess_win)
        t
    gui_contain.il. (I didn't put this inside a procedure because there's only one top level form)
    ; AB: removed unused variabls and stopped setting dock_W here
    (let (load_en reload_en loadpte_button reloadpte_button boxLayout_ver )
      load_en = t
      reload_en = nil
        ?callback "loadpte(hiGetCurrentForm())"
        ?enabled load_en
        ?callback "loadpte(hiGetCurrentForm() t)"
        ?enabled reload_en
        'boxLayout_ver
    ; AB: put the form and dock creation code within a function
    ; also removed unused local vars
    procedure(CreateDockWinForm(sess_win)
      let((addMosW_string addMosW_button gridLayout dock_W theForm boxLayout formName)
        formName=gensym('appForm)
          ?defValue "1.5"
          ?buttonText "apply"
          ?callback lsprintf("AddMosM1(%s)" formName)
          ?items (list
          'boxLayout
        theForm = hiCreateLayoutForm(
          formName "LAYOUT_PTE" boxLayout
          ?appType "layout"
          ?widgetType "form"
          ?form theForm
        hiDockWindow(
          ?window dock_W
          ?session sess_win
        ; AB: record it as a property on the window in case we need it later?
        sess_win->myDockWin=dock_W
        ; AB: return the dock window
        dock_W
    ; AB: pass the form to the callback
    procedure(AddMosM1(form)
      let((cv objs metal1 temp shapes x y ux uy xy row column transform M1_width)
        ; don't use evalstring. Imagine what happens if somebody types in exit() in the field!
        ;M1_width = evalstring(appForm~>addMosW_string~>value)
        M1_width = atof(form~>addMosW_string~>value)
        foreach(obj objs
          transform = nil
            x = xCoord(obj~>xy)
            y = yCoord(obj~>xy)
            ux = obj~>uX
            uy = obj~>uY
            row = obj~>rows
            for(a 0 row-1
              for(b 0 column-1
                ; AB: you can't use or within a case and you have duplicate values
                ; I changed the || to correct syntax (a list of candidates), but you'll need to fix the logic
                ; if "R0" or "MXR90" is found, only the first row will be chosen
                  (("R0" "MXR90") xy = list(x+a*ux : y+b*uy))
                  (("R90" "MY")   xy = list(x-a*ux : y+b*uy))
                  (("R0" "MXR90") xy = list(x+a*ux : y-b*uy))
                  (("R0" "MXR90") xy = list(x-a*ux : y-b*uy))
                );end case
              );end for
            );enf for
          );end if
              then
                );foreach
            );if
          );foreach
        );foreach
      );let
    );proc
    Good luck!
  • SZ20260803361
    Thank you so much for the revised code and the explanatory comments. I will go through it carefully to understand the changes.
    I totally agree with your suggestion about adding custom prefixes to my functions to prevent naming conflicts.
    I will test the logic for recreating dock windows. I may come back with further questions if I run into any issues.
    Thanks again for your great help!
