  3. Any node - Skill for the automatic ruler creation of user...
  • Views 829
Any node - Skill for the automatic ruler creation of user-defined lengths ( Working Fine)
yogeshjaiswalCAD
yogeshjaiswalCAD 2 months ago
Greetings All,
I am grateful for your assistance whenever I am in need. I aspire to contribute by enriching our community, as we consistently work to strengthen our connections.
After a detailed assessment of this code, I can affirm that it is an exemplary GUI-focused solution. It requires only the entry of the specified ruler length through the GUI and the binding key to be established just one time
 * YOGI_PRULER
 * 1. Load code in CIW followed by the procdeure name yogi_pruler_dim()
 * 2. Dimension GUI appears
 * 3. Enter exact dimension in um
 * 4  Click exact first point  (Start Point)
 * 5  Click anywhere for the second point in the direction you want to create the ruler ( X-Dir or Y-Dir)
 * 6. Exact measurement is created
;; MAIN ACTION CALLBACK: This handles drawing the ruler based on the form's value
procedure(yogi_pruler_action_cb(form)
    let((win cv dim p1 p2)
        ;; Get the current active window and its layout cellview content
        win = hiGetCurrentWindow()
        cv  = geGetWindowCellView(win)
        ;; Extract the target numeric dimension value directly from the user form
        dim = form->dimField->value
        ;; STEP 1: Ask the user to click the initial starting point of the ruler
        p1 = enterPoint(?prompts list("Click the starting point for your ruler"))
        when(p1
            ;; Convert the raw screen cursor coordinates to actual layout canvas coordinates
            p1 = geWindowToEditPoint(win p1)
            ;; STEP 2: Ask the user to click a second point to determine the drawing direction
            p2 = enterPoint(?prompts list("Click any point to indicate drawing direction"))
            when(p2
                ;; Convert the second screen coordinates to layout canvas coordinates
                p2 = geWindowToEditPoint(win p2)
                ;; STEP 3: Identify whether the user moved more Horizontally or Vertically
                if( abs(car(p2) - car(p1)) >= abs(cadr(p2) - cadr(p1)) then
                    ;; --- HORIZONTAL ROUTE ---
                    ;; If second click is to the right, project rightward. Otherwise, project leftward.
                    if(car(p2) >= car(p1) then
                        p2 = list(car(p1) + dim cadr(p1))
                    else
                        p2 = list(car(p1) - dim cadr(p1))
                else
                    ;; --- VERTICAL ROUTE ---
                    ;; If second click is higher, project upward. Otherwise, project downward.
                    if(cadr(p2) >= cadr(p1) then
                        p2 = list(car(p1) cadr(p1) + dim)
                    else
                        p2 = list(car(p1) cadr(p1) - dim)
                ;; STEP 4: Draw the fixed-dimension measurement ruler on the active layout canvas
                leCreateMeasurement(cv list(p1 p2))
;; MAIN EXECUTION FORM: Creates the user interface dialog box and displays it
procedure(yogi_pruler_dim()
    let((dimField)
        ;; Create a clean text box field specifically meant for decimal/float entries
        dimField = hiCreateFloatField(
            ?name 'dimField
            ?prompt "Ruler Dimension:"
            ?value 1.0
        ;; Construct the overall graphical user interface window wrapper
        hiCreateAppForm(
            ?name 'yogiPrulerForm
            ?formTitle "Yogi Precision Ruler"
            ;; Places the input box at dynamic positioning layout coordinates
            ?fields list(list(dimField 0:10 300:30 110))
            ;; Automatically triggers our simplified callback function when user clicks OK/Apply
            ?callback "yogi_pruler_action_cb(hiGetCurrentForm())"
            ?buttonLayout 'OKCancelApply
        ;; Pop the completed dialog interface onto the user's workspace screen
        hiDisplayForm(yogiPrulerForm)
I will wait for your response ,Once again thanks for warm gesture
Have a pleasant day!
Cheers & regards,
Yogesh Jaiswal
    Andrew Beckett 2 months ago +1
    yogeshjaiswalCAD said: I will wait for your response , Once again thanks for warm gesture There wasn't a question in your post, so I'm not sure what response you want? I would say that you can pretty…
  • yogeshjaiswalCAD
    yogeshjaiswalCAD 2 months ago in reply to Andrew Beckett +1
    Greetings Andrew, It means a lot when you take time from your busy schedule to reply :) The code is functioning as expected, thank you for reviewing it. I will take note of your suggestions to become…
    I would say that you can pretty much do this with built-in functionality. Simply start creating a ruler (Tools->Create Measurement, usually the "k" bind key), click on the first point (if you don't have infix enabled) and then press shift-N (that's the usual bind key). This pops up a form:
    If you check the "Use Relative XY" you can then enter 2 0 or 0 2 (or whichever direction you want it to go in) as the relative offset of the second point. Hit OK and then the ruler will be drawn.
    The shfit-N functionality can be used to enter points via a coordinate for anything where you are prompted to enter a point.
  • yogeshjaiswalCAD
    Greetings Andrew,
    The code is functioning as expected, thank you for reviewing it. I will take note of your suggestions to become more efficient with keyword usage... Have a pleasant day!
    Cheers & regards,
    Yogesh Jaiswal
