  3. How to get the top level coordinate of an instance on lower...
  • Replies 7
  • Views 1323
How to get the top level coordinate of an instance on lower level?
Martinsh
Martinsh 2 months ago
There is a cell named CellX in a hierarchical layout design. The cell CellX is placed on one of lower level of the layout design. How to get the top level coordinate of the bBox of the cell CellX?
Thanks!
    Andrew Beckett 2 months ago
    This code traverse the hierarchy finding matching cells and then transforms the bBoxes up to the top-level coordinate system. Hopefully this does what you want (I think I tested it enough...):
    /* CCFlistInstBBoxes.il
    Author     A.D.Beckett
    Group      CPG, Cadence Design Systems Inc.
    Language   SKILL
    Date       Sep 10, 2026
    Modified
    By
    This code traverses the hierarchy, collecting the transformations
    as it goes, and outputs the bBox point of any matching instance,
    searching based on the libName and/or cellName (also viewName if
    desired). If any of these criteria are unspecified, then matches all.
    e.g.
    cv=geGetEditCellView()
    instBoxes=CCFlistInstBBoxes(cv ?cellName "CELL1")
    instBoxes=CCFlistInstBBoxes(cv ?libName "mylib" ?cellName "CELL1")
    Handles mosaics (for OA releases only).
    SCCS Info: @(#) CCFlistInstBBoxes.il 09/10/26.23:11:15 1.1
    *         CCFlistInstBBoxes(cvId [?libName "libName"]          *
    *         [?cellName "cellName"] [?viewName "layout"]          *
    *                [?transform list(0:0 "R0" 1)]                 *
    *   Search the hierarchy recursively (including mosaics) for   *
    *  any inst that matches the given libName/cellName/viewName   *
    *   (if any are unspecified, they match all), and return the   *
    *      transformed bBox of the instance in the top-level       *
    *    coordinate system. Callers of this function would not     *
    *     normally pass ?transform - it's used internally when     *
    *                     called recursively.                      *
    procedure(CCFlistInstBBoxes(cvId @key
      libName cellName viewName
      (transform list(0:0 "R0" 1))
      let((instBBoxes)
        ; Recursively traverse the instances
        foreach(inst cvId~>instances
          when(inst~>objType=="inst"
            when((!libName || inst~>libName==libName) &&
                (!cellName || inst~>cellName==cellName) &&
                (!viewName || inst~>viewName==viewName)
              instBBoxes=cons(dbTransformBBox(inst~>bBox transform) instBBoxes)
            instBBoxes=nconc(
              CCFlistInstBBoxes(inst~>master ?libName libName
                ?cellName cellName ?viewName viewName
                ?transform dbConcatTransform(inst~>transform transform)
              instBBoxes
        ; Recursively traverse the mosaics (arrays). This is the most
        ; complicated part because you have to visit each row and column
        foreach(mosaic cvId~>mosaics
          let((master orient xy newTransform mosaicTransform)
            master=car(mosaic~>instanceList)~>master
            orient=car(mosaic~>tileArray)
            mosaicTransform=
              dbConcatTransform(
                dbConcatTransform(
                  list(mapcar('minus mosaic~>xy) "R0" 1)
                  list(0:0 orient 1)
                list(mosaic~>xy "R0" 1)
            ; Iterate over the rows and columns, visiting each
            ; sub-instance in the simple mosaic
            for(row 0 mosaic~>rows-1
              for(col 0 mosaic~>columns-1
                xy=xCoord(mosaic~>xy)+col*mosaic~>uX:yCoord(mosaic~>xy)+row*mosaic~>uY
                ; Compute the transformation of the sub-instance
                newTransform=
                  dbConcatTransform(
                    dbConcatTransform( list(xy "R0" 1) mosaicTransform)
                    transform
                when((!libName || mosaic~>libName==libName) &&
                    (!cellName || mosaic~>cellName==cellName) &&
                    (!viewName || mosaic~>viewName==viewName)
                  instBBoxes=cons(dbTransformBBox(master~>bBox newTransform) instBBoxes)
                instBBoxes=nconc(
                  CCFlistInstBBoxes(master ?libName libName
                    ?transform newTransform
                  instBBoxes
      instBBoxes
  • Martinsh
    Martinsh 2 months ago in reply to Andrew Beckett
    Andrew,
    Thanks a lot!
    Martinsh
  • Martinsh
    Hi, Andrew,
    Can we use function dbProduceOverlap()  and dbTransformBBox() to get the top level coordinate of a lower level instance?
    Martinsh
    Andrew Beckett 2 months ago in reply to Martinsh
    Yes, although I'd probably use dbInstQuery to just get the instances rather than potentially getting shapes. You'd probably also want to use dbGetHierPathTransform to compute the overall transformation from each return value of dbInstQuery. The one thing that is not built-in is retrieving the leaf-level object (so you could check it's an instance of the right cell) - you can use abGetHierPathShape from this post: https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/57612/how-to-use-dbshapequery-to-get-rect-bbox-from-bottom-to-top-in-mosaic-type/1391688
  • Martinsh
    Hi, Andrew,
    I write following code to get the transform of CellX to top level. But the final result is the transform of Cell1OnTop. What's wrong?
    let((cv)
        cv = geGetEditCellView()
        insts = dbInstQuery(cv cv~>bBox 0 32)
        foreach(inst insts
        when(listp(inst)
            when(car(last(inst~>cellName))=="CellX"
                println(inst~>cellName)
                println(inst~>transform)
                println(dbGetHierPathTransform(inst))
    Result:
    ("Cell1OnTop" "CellX")
    (((445.39 -8.675) "R0" 1.0) ((399.61 536.045) "MYR90" 1.0))
    Martinsh
    Actually, it's not doing that. You're getting the transformation of the final instance, rather than to a shape within that final instance.
    If there had been more levels of hierarchy, you'd see it's the concatenated transformations excluding the final instance. One way of seeing this would be if you did:
    dbCreateRect(cv "Metal4" dbTransformBBox(car(last(inst))~>bBox dbGetHierPathTransform(inst)))
    This would draw the rectangle exactly covering the final leaf instance. That's because the bBox is already the bBox of the final rotated/mirrored/translated instance, so it doesn't need the final transformation applied.
    Or you could do:
    dbCopyFig(car(last(inst)) cv dbGetHierPathTransform(inst))
    which would take the leaf instance (with it's transformation) and then copy that to the top-level.
    To illustrate what I mean, if you went down inside the final instance and used something inside that, you'd need to include the final leaf's transformation - which is what dbGetInstTransform does:
    dbCreateRect(cv "Metal5" dbTransformBBox(car(last(inst))~>master~>bBox dbGetInstTransform(inst)))
    Because the bBox is taken here from the master, it's in the coordinate system of the final cellView itself rather than the parent instance - so needs the extra level of transformation to be taken into account.
    Hope that helps (and my explanation was not too confusing).
  • Martinsh
    Hi, Andraw,
    It's clear now. Thanks a lot!
    BR,
    Martinsh
