  3. Does GDS contain prBoundary information?
  • Subscribers 150
  • Views 370
AR202509246930
AR202509246930 2 months ago
Will a cell’s prBoundary be present in the GDS after streaming out the layout.oa view? If yes, will it be stored as a normal polygon on the mapped GDS layer/datatype, or will the actual prBoundary object information be preserved?
Thanks.
    Andrew Beckett 2 months ago
    There's no dedicated structure in the Stream (aka GDS) format, so you can use the object map file in the stream out UI to map it to a layer/datatype combination - and that can be mapped back the other way for stream in.
