  3. Getting Simulation Files information using SKILL
  • Subscribers 152
  • Views 484
EO202501269056
EO202501269056 1 month ago
Hello! I am currently trying to find a way to get 'Parasitic Files (SPEF)' and 'PSpice Files' information from ADE Assembler/Explorer, found under Setup > Simulation Files. I need to automate this process using SKILL. So far, I cannot find a function or a way to extract these two pieces of information. Any advice?
  • henker
    henker 22 days ago +1
    These are part of the environment option, y ou can use maeGetEnvOption to extract the current entries resp. maeSetEnvOption to set them. Documentation is in Virtuoso ADE SKILL Reference There is/was…
  • EO202501269056
    EO202501269056 22 days ago
    If anyone can offer advice, it would be very helpful
  • henker
    henker 22 days ago
    These are part of the environment option, you can use maeGetEnvOption to extract the current entries resp. maeSetEnvOption to set them. Documentation is in Virtuoso ADE SKILL Reference
    There is/was a problem with dspf, where as workaround asiSetEnvOptionVal had to be used, see https://ask.cadence.com/ASK/article-viewer?id=a1O3w000009l1qmEAA&pageName=article-viewer
  • EO202501269056
    EO202501269056 18 days ago in reply to henker
    I tried it now and it worked! Thank you henker !
