  3. Looking for Virtuoso L/XL feature or SKILL that will allow...
  • Views 346
Looking for Virtuoso L/XL feature or SKILL that will allow select by line to select odd/even objects
Finn Huckle
Finn Huckle 1 month ago
Hi Cadence Community,
I am using select by line on Virtuoso L/XL.
Is there a built in feature that will allow me to select odd/even objects only.
For example If  have a row of mos devices and would start select by line from the left.
It will only select the 1st, 3rd, 5th ...etc. object for odd.
The same goes for even objects.
Please help.
  • Aurel B
    Aurel B 1 month ago +1
    ( inScheme ( defun select_aligned ( @key ( obj ( car ( geGetSelectedSet )) ) ( cv obj -> cellView ) ( direction ' horizontal ) ( modulo 2 ) ( shift 0 ) @rest _ ) "Return objects in CV that have…
  • Aurel B
    Aurel B 1 month ago
    (inScheme
      (defun select_aligned ( @key
                              ( obj       (car (geGetSelectedSet)) )
                              ( cv        obj->cellView            )
                              ( direction 'horizontal              )
                              ( modulo    2                        )
                              ( shift     0                        )
                              @rest _ )
        "Return objects in CV that have the same master as OBJ and are aligned with it according to DIRECTION.
    Returned list of objects is filtered by MODULO and SHIFT."
        ;; Check inputs
        (assert (dbobjectp obj)                                      "select_aligned - ?obj should be a dbobject: %N" cv)
        (assert (and (dbobjectp cv ) (equal "cellView" cv->objType)) "select_aligned - ?cv should be a cellview: %N"  cv)
        (letseq ( ( x           (xCoord (lowerLeft obj->bBox)) )
                  ( y           (yCoord (lowerLeft obj->bBox)) )
                  ( master      obj->master                    )
                  ( index       0                              )
                  ( targets     (cond
                                  ( obj->isAnyInst cv->instances )
                                  ( obj->isShape   cv->shapes    )
                                  ( t (error "select_aligned - ?obj should be an instance or a shape: %N %N" obj obj->objType) )
                  ;; Function to check similarity
                  ( is_similar? (case obj->objType
                                  ( "inst" (lambda (o) (eq master o->master))           )
                                  ( t      (lambda (o) (equal obj->objType o->objType)) )
                  ;; Function to check alignment
                  ( is_aligned? (caseq direction
                                  ( ( vert  vertical   ) (lambda (o) (nearlyEqual x (xCoord (lowerLeft o->bBox)))) )
                                  ( ( horiz horizontal ) (lambda (o) (nearlyEqual y (yCoord (lowerLeft o->bBox)))) )
                                  ( t (error "select_aligned - ?direction is not in '( vert vertical horiz horizontal ): %N" direction) )
          ;; Filter similar and aligned instances
          (setq targets (setof o targets (and (is_similar? o) (is_aligned? o))))
          ;; Sort instances by coordinates
          (setq targets
            (sort targets
              (caseq direction
                ( ( vert  vertical   ) (lambda (o0 o1) (lessp (yCoord (lowerLeft o0->bBox)) (yCoord (lowerLeft o1->bBox)))) )
                ( ( horiz horizontal ) (lambda (o0 o1) (lessp (xCoord (lowerLeft o0->bBox)) (xCoord (lowerLeft o1->bBox)))) )
          ;; Filter by modulo and shift
          (setq targets (setof _o targets (eq shift (mod index++ modulo))))
          ;; Select resulting objects
          (geDeselectAllFig)
          (geSelectFigs targets)
      );SKILL++
    ;; Examples
    ; (select_aligned)                  ; select even similar objects aligned horizontally
    ; (select_aligned ?shift     1)     ; select odd  similar objects aligned horizontally
    ; (select_aligned ?direction 'vert) ; select even similar objects aligned vertically
