  3. Refining Cell Placement at Routing Stage
  • Replies 17
  • Subscribers 94
  • Views 22378
Scrivner
Scrivner over 17 years ago
Does anyone know if there's a convenient way to refine cell placement to help alleviate routing congestion?
I often have highly congested routing areas in my design that could be helped by reducing the cell placement density in that area. But in order to refine the placement means that I have to go back to the floorplanning stage and add placement partial blockages and then go through the flow again basically from scratch. I want to be able to refine the placement at the post-CTS, post-timing optimization phase of the flow. I've tried using the "refinePlace" command, but it never seems to do anything (I assume because it works off of placement congestion instead of routing congestion).
 Thanks in advance for any ideas - Bart
  • Kari
    Kari over 17 years ago
     refinePlace didn't do anything because your placement was already legal.
    Can you detect the routing congestion earlier in the flow, so you're not going back so many steps? Or does the routing congestion appear only after CTS, or only after postCTSOpt, or only after hold fixing? If so, the original placement may not be the problem, or at least not the whole problem. Just throwing out some ideas.
  • Scrivner
    I can usually see where congestion spots will be, but I don't know which ones are going to be the worst routing bottleneck until after CTS and hold fixing. I usually just have one or two very small areas that end up being heavily congested to the point where it has trouble fixing all the routing violations. But 10 rows away, I might have any area where the placement utilization and routing congestion is very low. It would be nice to able to just automatically shift some of the cells from the congested area into the less utilized area. I currently have done this by hand and it has worked, but it's a pain because I have to do it manually.
    Kari - you seem to be the expert so if you don't know of a way to do this I guess there propbably isn't one. :)
  • lisiang
    lisiang over 17 years ago
     if you know it is always the same module with congestion problem, you can use "specifyInstPad inst_name  integer".  You can use wildcards for the inst. name and you need to play around with the "integer" to get a good placement.
    li siang
  • Kari
     There's plenty I don't know, believe me! :-) HOWEVER, I came across something: after you find your congested area, add a density screen (partial placement blockage) and then try placeDesign -incremental. Let me know if this works for you!
  • Scrivner
    That's a good suggestion Li Siang. It sounds like thay may help with my problem. I will try that on my new project coming up. Thanks for the suggestion!
  • Scrivner
    See - you DO know everything! :) This is what I was looking for. I think between this and trying what Li Siang suggested, I should be able to alleviated some of the congestion problems. Thanks!
  • PhilBzh
    PhilBzh over 15 years ago
     Hi Kari,
    I just found this 2008 subject as I was searching informations on that congestion problem.
    You wrote that there are severale solutions to solve congestion problems at cells placement. Could you please explain some others of these ?
     Thanks.
    Phil
  • Kari
    Kari over 15 years ago
     Hi Phil,
     I don't see where I said that in this thread, but you should look into density screens (partial placement blockage) and cell padding (specifyCellPad). These are two typical ways to make sure the initial placement isn't too congested.
    - Kari
  • PhilBzh
     Thank you Kari,
    I used cell padding and solve my congestion problem.
     Phil
  • Kari
     Phil,
    That's great news! Thanks for posting back that you were successful.
    - Kari
