  3. captables
  • Subscribers 92
  • Views 14223
captables
spach
spach over 16 years ago
hi
can any one explain the need of capacitance tables?
and what are the different ways of generating captables?
regards
suresh
  • Kari
    Kari over 16 years ago
     The captable is used for the built-in extraction in Encounter. This is used during the earlier steps of the flow before you have real routes with Nanoroute and start using a sign-off extractor like QRC. (You can use the Encounter extraction anywhere in the flow, but typically once you have post-route data, you start using sign-off extraction.) If you don't have a captable, you can still run through the flow, but I believe the cap and resistance numbers from the LEF are used, and these are not always very accurate. So I highly recommend using a captable.
    To create the captable, you use the command generateCapTbl (see the command file reference for more details). The captable is created using the .ict file for your process.You can also pass your tech LEF to generateCapTbl. This is recommended if you are using any NONDEFAULT rules (rules for routing wider than min width).
