  3. Virtuoso Stream In
  • Subscribers 92
  • Views 14444
Virtuoso Stream In
Mooty
Mooty over 16 years ago
 When I stream in my gds file to virtuoso, I get an unknown layer VIA_2C$$$$... etc (where $$$ are some arbitrary numbers and $) which gives problems when I attempt to do a DRC.  May I know how can I remove this layer?
yours faithfully,
Xiao Chuan
  • Kari
    Kari over 16 years ago
     Have you double-checked the stream map file that Encounter is using, to make sure all the layer numbers are valid and match your GDS stream map?
