  3. What is a manufaturing grid ?
  • Replies 16
  • Subscribers 100
  • Views 39311
NAADHAN
NAADHAN over 17 years ago
Hi All,
                 Can anyone explain me what is a manufaturing GRID  & its significance in our design?
Thanks & regards,
NAADHAN
  • Kari
    Kari over 15 years ago
     Move the MANUFACTURINGGRID line to your first lef, right after the END UNITS line. That should work.
  • yushuangming
    yushuangming over 15 years ago
    Thank you Kari! it works, error is gone.
  • VEERAMACHINENI
    VEERAMACHINENI over 9 years ago
    Hi...
    **ERROR: (GLOBAL-105): Unknown global 'timing_constraint_enable_property_keywords_with_filter_expression' specified
    can anyone suggest how to resolve this error while running placement.....?
  • Kari
    Kari over 9 years ago
    looks like the design was saved in a different version where this was a valid setting. you can remove it from the globals.
  • Satish Gupta
    Satish Gupta over 5 years ago in reply to Kari
    Hello Maam, any shape means does it include halo also.
    If i add a halo to block and if it doesn't allign with manufacturing grid, will I get DRC error?
  • Layla
    Layla over 5 years ago in reply to andries
    andries said:
    версия 5.1
    Hey! I really liked version 5.1 although I thought that something more updated would be needed. In general, everything is ok.
    With&Regards, developer view
