  3. Reset tree skew
  • Subscribers 94
  • Views 15499
Reset tree skew
290702500
290702500 over 16 years ago
I do a clock tree for reset signal, but how about the MaxSKew in CTS specify file.
the skew is small, it will waste area.
so how to set the MaxSKew?
thank a lot!
  • Kari
    Kari over 16 years ago
     For a reset tree, you can relax the skew target quite a bit. All that matters is that you're meeting timing. The insertion delay will be more what you want to control.
  • frankz
    frankz over 16 years ago
     It is just a buffer tree and you just need to care about the transition.
    You don't even want to use the clock buffer for this tree.
  • Ran Fisher
    Ran Fisher over 16 years ago
    I disagree with Frankz. Throughout the various release of Encounter I've been promised that it can do this well, but I still don't like the results. From some trials I did I found that the buffer tree inserted by Encounter is not optimized. Encounter takes care for transition, but it uses more buffers and has larger delay than when creating it with CTS.
    After I run CTS I remove the buffer trees created on large fanout nets (resets, shift_enable, etc.) and use the CTS engine to create the optimized tree. You can see my little procedure below. You have to prepare a file, a list and decide on the delay/skew/transition values.
    deleteBufferTree -selNetFile remove_buffertree.txt -allowCreateAssign
    foreach elem $HIGH_FANOUT_LIST {
      bufferTreeSynthesis -bufList $tree_buffers -fixedBuf -fixedNet \
                          -maxDelay $tree_maxDelay \
                          -maxSkew  $tree_maxSkew \
                          -maxTran  $tree_maxTran \
                          -prefix ${elem}_tree \
                          -nets $elem
  • frankz
    I never expect Cadence tool will generate good result for me.
    I just use it to build a buffer tree which looks OK then manually fix big transition violations.
     Regards.
