  3. Can someone know command-like rename $oldname $newname in...
  • Subscribers 92
  • Views 14868
Can someone know command-like rename $oldname $newname in Encounter
magicflute
magicflute over 16 years ago
i can not find the command that rename  hier inst name  in db command. can someone tell me ?
  • magicflute
    i searched all of db command ,but i can find nothing to achieve the function.  can someone also give me a script ?
  • wally1
    wally1 over 16 years ago
    The only time module names are modified in Encounter is during uniquification with uniquifyNetlist. Outside of this you'll have to manually change the name in the Verilog.
  • Rajesh Vembu
    Rajesh Vembu over 16 years ago
     Have you tried changeInstName command?
    This changes only the leaf level instance name, that is, if you have an instance A/B/C (where C is an instance defined in module B, which is instantiated in module A ) and you want to change the name of C, you have to execute
    changeInstName -instName A/B/C -newBaseName A/B/CNew
    Note : The changeInstName command does not change the path of hierarchy
    The only way to change the hierarchy instance name is
    1. unFlatten <HierModule>
    2. changeInstName -instName <HierModuleName> -newBaseName <newHierModuleName>
    3. flatten the design
    Please try it and let me know if it works for you.
