  3. Encounter Termination
  • Subscribers 92
  • Views 14352
Kevin P Thomas
Kevin P Thomas over 16 years ago
*** Memory Usage v0.134.4.2 (Current mem = 499.480M, initial mem = 115.797M) ***
encounter 26> Encounter terminated by internal (SEGV) error/signal...
*** Stack trace in log file.
\266\257\300\251\275\252\316\273
Can you please suggest the solution for this issue
  • Kari
    Kari over 16 years ago
    Hi Kevin,
    This is not enough information to tell what's going on. What was Encounter doing right before the crash? What's in the log file before this point? You may have some errors or warnings previous to this that need to be looked into.
    - Kari
  • Kevin P Thomas
    Kevin P Thomas over 14 years ago
    Hi Kari
     Sorry for the late reply.
    I attached the termination details below:-
     <CMD> zoomOut
    <CMD> zoomOut
    <CMD> selectInst UP_TOP/UANCH_TXDQ_DLLLCLK_INV1
    <CMD> selectInst UP_TOP/UANCH_X2CLK_INV1
    <CMD> selectInst UP_TOP/UANCH_X2CLKX_INV1
    <CMD> deselectAll
    <CMD> deselectAll
    <CMD> report_property [get_cells UP_TOP/UANCH_X2CLK_INV1]
    property                            | value
    area                                | 4.836
    early_cell_check_derate_factor      | 1.000
    early_clk_cell_derate_factor        | 1.000
    early_data_cell_derate_factor       | 1.000
    hierarchical_name                   | UP_TOP/UANCH_X2CLK_INV1
    has_sdc_assertions                  | false
    is_black_box                        | false
    *** Stack trace:
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(syStackTrace+0x136)[0x6c10e22]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity[0x134110d]
    /lib64/tls/libpthread.so.0[0x320c10c5b0]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(_ZN10TADelayArc6sourceEv+0x63)[0x6ec8cf3]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(_ZN7TATimer19computeDerivedFlagsEP10TADelayArc+0x33)[0x70884f3]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(_ZN7TATimer15calculateEndTagEP10TADelayArcR5TASetRsR15TAEndTagPinInfoR9tabooleanP11TATimingPin+0x311)[0x7184ba1]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(_ZN7TATimer15calculateEndTagEP11TATimingPiniR9taboolean+0x520)[0x7182e90]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(_ZN7TATimer15calculateEndTagEP10TADelayArcR5TASetRsR15TAEndTagPinInfoR9tabooleanP11TATimingPin+0x457)[0x7184ce7]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(_ZN7TATimer28isDynamicClockGatingEndPointEP11TATimingPinP10TABoundary+0x9c)[0x714a4fc]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(_ZN11TAattribute12getAttributeEP10TAInstanceNS_14attribute_typeEP7Tcl_Obj+0xdaa)[0x76953aa]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(_ZN18TAderivedAttributeI10TAInstanceE17getAttributeValueEPKvN11TAattribute14attribute_typeEP7Tcl_Obj+0xe)[0x76b9b8e]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(_Z21TACmd_report_propertyPvP10Tcl_InterpiPPc+0x366)[0x759a2f6]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(TclInvokeStringCommand+0x58)[0x8534438]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity[0x8576bae]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(TclEvalObjvInternal+0x13d)[0x853523d]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity[0x855735d]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(TclCompEvalObj+0x9b)[0x855676b]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(Tcl_EvalObjEx+0x1df)[0x853623f]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(Tcl_RecordAndEvalObj+0x96)[0x8562a16]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(Tcl_RecordAndEval+0x48)[0x8562908]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(_Z17rdaEditCmdLineEndPc+0x21b)[0x13250e7]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(_Z9elEndLinev+0xb8)[0x4d52334]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(_Z16callback_handlerPh+0x1d)[0x4d5404d]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(_Z21el_callback_read_charv+0x9d)[0x4d540ef]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity[0x4d54121]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity[0x8596b1c]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(Tcl_ServiceEvent+0x91)[0x8578fd1]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(Tcl_DoOneEvent+0x119)[0x85792a9]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/lib/64bit/libtq.so(_ZN17TqEventDispatcher13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE+0xb6)[0x2a995c2db2]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/Qt/64bit/lib/libQtCore.so.4(_ZN10QEventLoop13processEventsE6QFlagsINS_17ProcessEventsFlagEE+0x35)[0x2a97f2c5f5]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/Qt/64bit/lib/libQtCore.so.4(_ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE+0x98)[0x2a97f2c758]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/Qt/64bit/lib/libQtCore.so.4(_ZN16QCoreApplication4execEv+0xae)[0x2a97f2e6ae]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/lib/64bit/libtq.so(_ZN13TqApplication4execEv+0x2c1)[0x2a995c536f]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(_Z7fe_mainiPPc+0x327)[0x1323bc3]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(main+0x72)[0x1323c8a]
    /lib64/tls/libc.so.6(__libc_start_main+0xdb)[0x320ba1c40b]
    /eda/cdn/edis/9.1_usr3/tools.lnx86/fe/bin/64bit/velocity(_ZNK9QTreeView7indexAtERK6QPoint+0x6a)[0x132332a]
                   pstack
    Thread 6 (Thread 1075841376 (LWP 9752)):
    #0  0x000000320c10bc35 in __nanosleep_nocancel ()
    #1  0x0000000001cb398d in rdaiLicRecheck ()
    #2  0x000000320c106137 in start_thread () from /lib64/tls/libpthread.so.0
    #3  0x000000320bac9f03 in clone () from /lib64/tls/libc.so.6
    Thread 5 (Thread 1077942624 (LWP 9753)):
    #0  0x000000320ba90855 in __nanosleep_nocancel () from /lib64/tls/libc.so.6
    #1  0x000000320ba906c0 in sleep () from /lib64/tls/libc.so.6
    #2  0x0000000006c238f9 in syiPeakMem ()
    #3  0x000000320c106137 in start_thread () from /lib64/tls/libpthread.so.0
    #4  0x000000320bac9f03 in clone () from /lib64/tls/libc.so.6
    Thread 4 (Thread 1080043872 (LWP 9754)):
    #0  0x000000320bac2f56 in __select_nocancel () from /lib64/tls/libc.so.6
    #1  0x000000000859708d in NotifierThreadProc ()
    Thread 3 (Thread 1082145120 (LWP 9755)):
    #0  0x000000320c10c34b in do_sigwait () from /lib64/tls/libpthread.so.0
    #1  0x000000320c10c3fd in sigwait () from /lib64/tls/libpthread.so.0
    #2  0x0000000001341505 in ctrlCHandle ()
    Thread 2 (Thread 1086347616 (LWP 9768)):
    #1  0x0000002a97f56268 in QEventDispatcherUNIX::select ()
    #2  0x0000002a97f571f6 in QEventDispatcherUNIXPrivate::doSelect ()
    #3  0x0000002a97f57682 in QEventDispatcherUNIX::processEvents ()
    #4  0x0000002a97f2c5f5 in QEventLoop::processEvents ()
    #5  0x0000002a97f2c758 in QEventLoop::exec ()
    #6  0x0000002a97e42b58 in QThread::exec ()
    #7  0x0000002a97f14825 in QDnotifySignalThread::run ()
    #8  0x0000002a97e456d4 in QThreadPrivate::start ()
    #9  0x000000320c106137 in start_thread () from /lib64/tls/libpthread.so.0
    #10 0x000000320bac9f03 in clone () from /lib64/tls/libc.so.6
    Thread 1 (Thread 182987100416 (LWP 9697)):
    #0  0x000000320ba9022a in waitpid () from /lib64/tls/libc.so.6
    #1  0x000000320ba39b6f in do_system () from /lib64/tls/libc.so.6
    #2  0x000000320ba39de6 in system () from /lib64/tls/libc.so.6
    #3  0x0000000006c10e7a in syStackTrace ()
    #4  0x000000000134110d in rdaiErrorHandler ()
    #5  <signal handler called>
    #6  0x0000000006ec8cf3 in TADelayArc::source ()
    #7  0x00000000070884f3 in TATimer::computeDerivedFlags ()
    #8  0x0000000007184ba1 in TATimer::calculateEndTag ()
    #9  0x0000000007182e90 in TATimer::calculateEndTag ()
    #10 0x0000000007184ce7 in TATimer::calculateEndTag ()
    #11 0x0000000007182e90 in TATimer::calculateEndTag ()
    #12 0x000000000714a4fc in TATimer::isDynamicClockGatingEndPoint ()
    #13 0x00000000076953aa in TAattribute::getAttribute ()
    #14 0x00000000076b9b8e in TAderivedAttribute<TAInstance>::getAttributeValue ()
    #15 0x000000000759a2f6 in TACmd_report_property ()
    #16 0x0000000008534438 in TclInvokeStringCommand ()
    #17 0x0000000008576bae in InvokeImportedCmd ()
    #18 0x000000000853523d in TclEvalObjvInternal ()
    #19 0x000000000855735d in TclExecuteByteCode ()
    #20 0x000000000855676b in TclCompEvalObj ()
    #21 0x000000000853623f in Tcl_EvalObjEx ()
    #22 0x0000000008562a16 in Tcl_RecordAndEvalObj ()
    #23 0x0000000008562908 in Tcl_RecordAndEval ()
    #24 0x00000000013250e7 in rdaEditCmdLineEnd ()
    #25 0x0000000004d52334 in elEndLine ()
    #26 0x0000000004d5404d in callback_handler ()
    #27 0x0000000004d540ef in el_callback_read_char ()
    #28 0x0000000004d54121 in elReadlineHandler ()
    #29 0x0000000008596b1c in FileHandlerEventProc ()
    #30 0x0000000008578fd1 in Tcl_ServiceEvent ()
    #31 0x00000000085792a9 in Tcl_DoOneEvent ()
    #32 0x0000002a995c2db2 in TqEventDispatcher::processEvents ()
    #33 0x0000002a97f2c5f5 in QEventLoop::processEvents ()
    #34 0x0000002a97f2c758 in QEventLoop::exec ()
    #35 0x0000002a97f2e6ae in QCoreApplication::exec ()
    #36 0x0000002a995c536f in TqApplication::exec ()
    #37 0x0000000001323bc3 in fe_main ()
    #38 0x0000000001323c8a in main ()
                    gdb
    Using: gdb
    Using host libthread_db library "/lib64/tls/libthread_db.so.1".
    [Thread debugging using libthread_db enabled]
    [New Thread 182987100416 (LWP 9697)]
    [New Thread 1086347616 (LWP 9768)]
    [New Thread 1082145120 (LWP 9755)]
    [New Thread 1080043872 (LWP 9754)]
    [New Thread 1077942624 (LWP 9753)]
    [New Thread 1075841376 (LWP 9752)]
    #1  0x0000000001cb3941 in rdaiLicRecheck ()
       from /eda/cdn/edis/9.1_usr3/tools.lnx86/Qt/64bit/lib/libQtCore.so.4
       from /eda/cdn/edis/9.1_usr3/tools.lnx86/lib/64bit/libtq.so
    *** INTERRUPTED *** [signal 1]
  • Kari
    Kari over 14 years ago
     Please file a service request.
