  3. Locked files in Encounter Library Characterizer
  • Subscribers 92
  • Views 13882
mbhealy
mbhealy over 16 years ago
Hi All,
I am trying to use Library Characterizer and I am getting a very basic error that doesn't make any sense to me.
I start elc and run the command:
db_open test_run
Then I try to run
db_prepare -f
and I get the following error:
[ERROR(db_prepare)]Cannot access the design test_run because it is locked by [user] at Sun Oct 11 18:28:12 2009
. Use the 'db_clean -lock all' command to release the lock and try again.
If I run the db_clean line it doesn't help at all. I get the same error. If I delete the lock file: test_run.ipdb/ipdb.tech/lock/IPDB.dblock then elc Segfaults. What could possibly be causing a newly created database to be unaccessible?
Please help!
  • mbhealy
    I'm still having this problem.
    Here is a sample log file:
    Encounter - Library Characterizer - Version v08.13-s001_1 - linux_opt64 64-bit (09/17/2009 01:50:58)
    [2000-2009] Cadence Design Systems, Inc. All rights reserved.
    This work may not be copied, modified, re-published, uploaded, executed, or
    distributed in any way, in any medium, whether in whole or in part, without
    prior written permission from Cadence Design Systems, Inc.
    set_var MANPATH = /tools/linsoft2/cadence/ets81/share/elc/man:/usr/local/man:/usr/share/man:/usr/X11R6/man:/usr/apps/man
    elc> db_open test
    Database : test is now opened
    elc> db_close
    Database : test is closed
    elc> db_open test
    elc> db_prepare -f
    [ERROR(db_prepare)]Cannot access the design test because it is locked by mbhealy at Wed Oct 14 11:59:56 2009
    elc> db_close
    elc> db_prepare -f
    [WARNING(db_prepare)]Please open the database
    elc> db_open test
    elc> db_prepare -f
    elc> db_clean -all
    Remove all temp files
    elc> db_clean lock -all
    Release all locks
    elc> db_prepare -f
    elc>
    Here is my elccfg file. I am trying to run spice simulations on the local machine, so I have not started ipsc or ipsd. Is that okay? I would think the error would be different if that were the case. And anyway, I have tried using ipsc and ipsd as well. I still get the same problem.
    Here is also my elccfg file:
     #Specify the environment variable settings.
    EC_SIM_USE_LSF=1;
    EC_SIM_LSF_CMD=" ";
    EC_SIM_LSF_PARALLEL=2;
    EC_SIM_TYPE="hspice";
    EC_SIM_NAME="hspice";
    EC_SPICE_SIMPLIFY=1;
    EC_CHAR="ECSM-TIMING ECSM-POWER";
    #Specify the characterization inputs.
    SUBCKT="cells.sp";
    MODEL="allModels.scs";
    DESIGNS="AND2X1 AND2X2";
    SETUP="setup.default";
    PROCESS="typical";
    Does anyone see anything wrong with this?? Do I need to try to reinstall elc? Please help!
  • mbhealy
    It looks like this problem is related to some kind of configuration or installation error. I don't know what it is yet but for some reason elc won't work on a particular set of machines on our network. Other machines seem to work correctly, so for the time being I will be using those. Hopefully we can get it working on the original machines because they are faster.
