  3. Issues in shielding
  • Subscribers 93
  • Views 14612
Issues in shielding
PramodSabnis
PramodSabnis over 16 years ago
 I am facing this peculiar issue while trying to do shielding on clock nets.
 The flow followed is as follows:
- Set attributes on clock nets
- Apply the attribute in clock spec file
I also set the following variables:
- setNanoRouteMode -routeDeferredShield true
Router carries out shielding at the end of routing. However, what I see is that this ends with a plenty of "Wire Extension" category of DRCs on ths shield nets (not the shielded ones).
Has anyone seen this behaviour? How do I fix these violations in an automated manner (there are plenty of those so, manual fix is ruled out)?
Best regards,
Pramod
  • BobD
    BobD over 16 years ago
    Hi Pramod, Do you have access to the latest 8.1.USR3 release? I've been working with a customer recently who reported very similar issues to what you're describing that were resolved in bug fixes just recently. Thanks, Bob
  • PramodSabnis
    Hello Bob,
    Thanks for responding.
    Well, I was using SOC8.1. Not sure which exact version it is. This is what I found from logfile:
    @(#)CDS: First Encounter v08.10-s207_1 (32bit) 03/03/2009 17:59 (Linux 2.6)
    @(#)CDS: NanoRoute v08.10-s073 NR090226-1110/USR59-UB (database version 2.30, 71.1.1) {superthreading v1.11}
    @(#)CDS: CeltIC v08.11-s187_1 (32bit) 02/26/2009 16:16:51 (Linux 2.6.9-67.0.10.ELsmp)
    @(#)CDS: CTE v08.10-s163_1 (32bit) Mar  3 2009 15:23:39 (Linux 2.6.9-67.0.10.ELsmp)
    @(#)CDS: CPE v08.11-s010
    --- Starting "First Encounter v08.10-s207_1" on Mon Oct 19 01:32:46 2009 (mem=63.4M) ---
    If you could suggest me the version to be downloaded, i could try using it.
    Meanwhile, we saw two issues in the present case;
    - The LEF was wire extension based. This should have been Via Enclosure based
    - Problem was only when the tool was jogging to MET6 to hook up shield to power i.e. VSS
    What we did was, we added complete routing blockage on MET6 and above and ran createShield. That way, the router was forced to carry out the entire shielding on MET3,4 and 5.
    This was thanks to suggestion from Cadence AE.
    However, I would like to have the above done automatically and not bother to do it in every timing iteration.
    Thanks for your inputs as well. I will try to use the version of tool you have suggested and keep this posted.
    Best regards,
    Pramod
  • BobD
    Hi Pramod,
    Thanks for your reply.  Sounds like you're getting helpful advice from your AE- I'm glad to hear that.
    8.1.s207 is USR1.  The version I'd suggest you pick up is SOC_EDI8.1_USR3_s338.  You can get it here:
    http://downloads.cadence.com
    • Select your platform
    • Select SOC81
    • Select USR3
    The problems you're seeing continue to sound similar to what I heard from the other customer I worked with.  Please do test this newer version and let us know if it resolves the issue either way.  If it does resolve the issue, it would be good for others to know about, and if it does not then we'll want to make sure the software is repaired so it handles the situation automatically.
    Thanks!
    Bob
  • Chinmayananda
    Chinmayananda over 15 years ago
    HI ,
    We do see same issue with SOC81-USR3 .We found this when we ran DRC using caliber .
    Now we don't have choice to change the tool version .
    Is there any work-arround for this problem ???
    -Swamy .
