  3. Filtering of false DRC violations due to routing blockages...
  • Subscribers 91
  • Views 13966
Filtering of false DRC violations due to routing blockages in enounter.
KVBABU
KVBABU over 16 years ago
Hi All,
 I am implementing a  mixed signal design , in which i have huge number of custom routes in many areas. As a result we are employing routing blockages in those areas.  i.e. for example, i will route a custom net using metal3 and i will block further routing  of metal 3 in those areas. Like those , we have huge number of such  areas. So finally , after completing routing with Nanoroute, if i verify geometry  using the command
  verifyGeometry -noRoutingBlkg
it is not filtering out the false violations with blockages. If there is any real violation, then it is tedious for me to manuulay filter out all thesefalse one's and trace out real violations.
Is there any way to mask these violations. Please suggest me .
Thanks in advance,
K.VISWANADH BABU
  • BobD
    BobD over 16 years ago
    I did a test here on a small design and I'm unable to reproduce the problem you're seeing.  Here's what I did:
    I created a regular signal route with NanoRotue on M1 and placed a routing blockage over it.  I ran verifyGeometry and I saw a drc violation appear.  Then I cleared the violation markers and ran verifyGeometry -noRoutingBlkg.  The violation didn't appear.
    I also tried converting the route to a special route- still no violation reported with verifyGeometry -noRoutingBlkg.  I also tried marking the routes FIXED- still no violation reported with verifyGeometry.
    Let me know if you can think of any nuance that might be present in your situation that is different than what I've described here.  I've used 8.1.USR3 for my testing- let me know if you're on an earlier version and I can re-run these same tests.  If still no resolution then please file a service requrest at http://support.cadence.com
    Bob
