  3. How can I cut a routing blockage in FE?
  • Replies 7
  • Subscribers 92
  • Views 18626
archive over 18 years ago
Dear ALL:
I want to cut a routing blockage in one floorplan to make routing guides. For example, I dont have M5 cell routing blockage in a LEF hard block, I add this routing blockage at the top level, I have to cut some notches according to the pin shapes (if pins are on M5), then router can make M5 connections to these pins without DRC. How can I cut these notches on the added M5 routing blockage, this is more like a polygon operation, do Encounter have such db commands? I dont want to modify the LEF file (to add the M5 obstruction).
Thanks in advance!
Originally posted in cdnusers.org by eminemshow
    You can use another solution.
    You can specify, attach to your block, a routing halo, like a placement blockage halo.
    In the documentation it is specified that it prohib routing on top of the macro on the specified layer, but allow the router to connect macro pins on this layer (Straigth connection).
    Originally posted in cdnusers.org by bougantp
  • patrice06
    patrice06 over 14 years ago
    To comment on this old post: Using a routing halo does not prevent the router to route over and fully across the macros on the specified layer. At least, this is what I am observing in my current design. Unfortunately.
    Looks like, I have to go for obstruction layer defined for each macro instance, with the options to leave the acess to pin and special nets. (I want to avoid top level routing over memories)
    Best Regards
    patrice
  • Kari
    Kari over 14 years ago
     A Routing Halo is mean to prevent parallel wires at block boundaries, to avoid hidden SI issues. To completely block routing over a block, you need a routing blockage, as you said.
  • BobD
    BobD over 14 years ago
    Thanks for raising this item up Kari. To create routing blockages above all hard macros in the design, pulled in by 5 microns for pin access one could do something like this:
    foreach box [dbShape [dbGet [dbGet -p2 top.insts.cell.baseClass block].boxes] SIZE -5] {createRouteBlk -layer all -box $box}
  • patrice06
    Hi Bob,
    Thanks for this feedback. I am trying to implement this but I have a couple of issue. As I am a beginner with dbGet, I did run some experiments but I am a bit stuck.
    I am using SOC 8.1
    There were complains about boxes (not recognized as attributes. Expected : box ?) and dbShape (ex: dbShapeRect now ?). So, I am cuurently with :
    foreach box [dbShapeRect [dbGet -p [dbGet -p2 top.insts.cell.baseClass block].box] SIZE -5] {createRouteBlk -layer 5 -box $box}
    I have added the -p to return pointers but dbShapeRect still complains it expects a pointer (I got: Usage: dbShapeRect <ShapePtr>)
    However, If I type only : dbGet -p [dbGet -p2 top.insts.cell.baseClass block].box
    0x11fa2f038 0x11fb5e5b0
    that gives a list of pointers and seem correct, so i don't know what is the issue.
    In case you could have a look as this is obviously a very useful ietms for many design.
    Patrice
  • BobD
    The dbShape command debuted in 10.1 and dbGet didn't always expose the "boxes" field. Can you move to a newer version?
    If not, you'd need to write your own shape maniuplation commands and retrieve the box list with getObjFPlanBoxList.
    You may be better off adding the blockage shapes to the LEF (in which case you may not need to cut out around the pins because routers like NanoRoute can automatically access a pin covered with a blockage within a LEF).
    Bob
  • patrice06
    Hi Bob,
    I will move to 10.1 after completing this design.
    In this design, I prefer not incorporate the blockage inside the LEF as I still allow power routing over the macro in the floorplan. So, it is nice to be able to generate those blockage on the fly and delete before checking for violation.
    I am currently using this : foreach inst [dbGet [dbGet -p2 top.insts.cell.baseClass block].name] {createRouteBlk -cover -exceptpgnet -layer 5  -inst $inst}
    layer 5 is my top metal.    That covers the macro.  That is already doing a good job. The sizing would have also allow access in the top metal to the pins. But not an issue for this design.
    Thanks a lot for your answer.
    Patrice
