  3. Getting critical path extraction from encounter to spic...
  • Subscribers 92
  • Views 15131
Getting critical path extraction from encounter to spice
Jdevos
Jdevos over 16 years ago
I've analyzed a circuit with encounter and I've found the critical path. Now I would like to make a Monte Carlo analysis of this path with a spice simulator.
My point is therefore to know if there is a way to extract the spice netlist of my critical path? I've tried to use the ETS tool but it asked me for a cdB file in order to perform a noise calculation. However I don't have this file for the design kit I'm using. Moreover I don't feel it is really necessary to make a noise calculation in order to extract the critical path in a spice file. Therefore my question is: is there another way to get this file?
Thanks a lot for your help!
  • Kari
    Kari over 16 years ago
    According to the documentation, you don't have to run a noise analysis to get the spice, but you do have to issue the "set_noise_run_mode" command before the "create_spice_deck -report_timing" command. Try providing a "dummy" cdB file and see if you can get your spice output. Let us know if it works!
  • Jdevos
    Hi Kari
    First of all thanks a lot for your help.
    I've tried to load a dummy cdB as you suggested but it doesn't work. Actually after executing the command create_spice_deck, I got the following warning :
    "**WARN:  (SI-2252) SPICE trace cannot be simulated or output. The noise library (cdB) data needs to be loaded prior to running the set_noise_run_mode command. You can use the read_lib -cdb to load the noise library (cdB) files or specify it through a configuration file." (Although my cdB file is loaded with my .conf)
    Just below I got several warnings like this one:
    "**WARN: (SI-2000) cdB may be missing spice definition for cell HS65_LS_IVX7 (needed for port clk__L1_I0:A)                    [sim_path]"
    To be sure I'm not missing something, here is a list of the commands I execute after loading my .conf (the dummy cdb is loaded in the .conf)
    read_spef file.spef
    set_noise_run_mode -process 65nm
    set_noise_parm spice_include {nameofmy.spi}
    create_spice_deck
    (I've tried some other things but I got the same result)
  • Kari
    Kari over 15 years ago
    Did you get this working? Hopefully you filed a service request and someone was able to help you.
    - Kari
