  3. Encounter crashes -> Internal error (SEGV)
  • Subscribers 92
  • Views 2833
CriGri
CriGri over 15 years ago
Hi @ all!
I am new in the community. I'm a student and i work part time in the university. Just now i'm trying to get familiar with encounter (Ver.7.1).
My problem is that encounter crashes after setting up the database. It would be great if anyone may help me. The log is below.
 Thank u!
This version requires license using cdslmd daemon.
Checking out Encounter license ...
SOC_Encounter_GXL 7.1 license checkout succeeded.
INFO: Current OA version selected: OA22
INFO: This Encounter release has been compiled with OA data Model 4 and OA version p026.
sourcing /Cadence/soc7.10/tools.lnx86/fe/etc/rdaDSL.tcl
*   Copyright (c)  Cadence Design Systems, Inc.  1996 - 2008.     *
*                     All rights reserved.                        *
* This program contains confidential and trade secret information *
* of Cadence Design Systems, Inc. and is protected by copyright   *
* law and international treaties.  Any reproduction, use,         *
* distribution or disclosure of this program or any portion of it,*
* or any attempt to obtain a human-readable version of this       *
* program, without the express, prior written consent of          *
* Cadence Design Systems, Inc., is strictly prohibited.           *
*                 Cadence Design Systems, Inc.                    *
*                    2655 Seely Avenue                            *
*                   San Jose, CA 95134,  USA                      *
@(#)CDS: First Encounter v07.10-s219_1 (32bit) 09/11/2008 21:51 (Linux 2.4)
@(#)CDS: NanoRoute v07.10-s194 NR080828-1515/USR56-UB (database version 2.30, 63.1.1) {superthreading v1.10}
@(#)CDS: CeltIC v07.10-s274_1 (32bit) 09/04/2008 02:57:35 (Linux 2.4.21-37.ELsmp)
@(#)CDS: CTE v07.10-s203_1 (32bit) Sep 10 2008 12:45:53 (Linux 2.4.21-37.ELsmp)
@(#)CDS: CPE v07.13-s009
--- Starting "First Encounter v07.10-s219_1" on Mon Dec  7 12:31:36 (mem=74.1M) ---
--- Running on torino (x86_64 w/Linux 2.6.18-164.6.1.el5) ---
This version was compiled on Thu Sep 11 21:51:14 PDT 2008.
Set DBUPerIGU to 1000.
Set Default Mode Capacitance Scale Factor to 1.00
Set Detail Mode Capacitance Scale Factor to 1.00
Set Coupling Capacitance Scale Factor to 1.00
Set Resistance Scale Factor to 1.00
Set net toggle Scale Factor to 1.00
Set Shrink Factor to 1.00000
<CMD> loadConfig /home/grigor/digback/encounter/c35b4_std.conf 0
Reading config file - /home/grigor/digback/encounter/c35b4_std.conf
<CMD> commitConfig
**WARN: (SOCSYT-20004):    Both ui_leffile and ui_oa_reflib are defined. Standard Cell and Technology data will be read from the LEF files specified in ui_leffile. Libraries defined in ui_oa_reflib will be used to read custom layers from OA. If OA reference libraries  are available, the recommended method is to only define ui_oa_reflib and not define ui_leffile.
Loading Lef file /Cadence/hk4.00/cds/HK_C35/LEF/c35b4/c35b4.lef...
**WARN: (SOCLF-228):     ANTENNAOUTPUTDIFFAREA is specified and will be
applied to any OUTPUT PIN or INOUT PIN without ANTENNADIFFAREA. This often
causes a mismatch between process antenna violations found in Encounter
(during routing or verify) and violations found by external physical
verification tools. This global defaulting mechanism is obsolete in LEF
5.5. The recommended solution is to remove ANTENNAOUTPUTDIFFAREA and add
ANTENNADIFFAREA to all OUTPUT or INOUT PINS in the MACROS in order to
avoid a mismatch in violations.
**WARN: (SOCLF-230):     ANTENNAINOUTDIFFAREA is specified and will be
applied to any INOUT PIN without ANTENNADIFFAREA. This often causes a
mismatch between process antenna violations found in Encounter (during
LEF 5.5. The recommended solution is to remove ANTENNAINOUTDIFFAREA
and add ANTENNADIFFAREA to all INOUT PINS in the MACROS in order to
Loading Lef file /Cadence/hk4.00/cds/HK_C35/LEF/c35b4/CORELIB.lef...
Set DBUPerIGU to M2 pitch 1400.
Initializing default via types and wire widths ...
Loading Lef file /Cadence/hk4.00/cds/HK_C35/LEF/c35b4/IOLIB_4M.lef...
Loading Lef file LEF/ablock.lef...
**WARN: (SOCLF-78):    First Encounter only takes the
MANUFACTURINGGRID (or MINFEATURE) statement from the
technology lef file (first one in the list), or a default
value is set. The MANUFACTURINGGRID value 0.005000 defined in the
lef file LEF/ablock.lef is different from
the one in db. Make sure the data in the specified lef file is
compatible with the technology lef file.
Loading Lef file LEF/sram256x8.lef...
Loading Lef file LEF/sram1024x8.lef...
**WARN: (SOCLF-200):    Pin 'DO[5]' in macro 'sram1024x8' has no ANTENNADIFFAREA attribute defined.
For any non-power/ground input or inout pin, The attribute should be
defined if any area ratio antenna attribute is defined on any layer.
**WARN: (SOCLF-200):    Pin 'DO[6]' in macro 'sram1024x8' has no ANTENNADIFFAREA attribute defined.
**WARN: (SOCLF-200):    Pin 'DO[7]' in macro 'sram1024x8' has no ANTENNADIFFAREA attribute defined.
**WARN: (SOCLF-200):    Pin 'NRST' in macro 'sram1024x8' has no ANTENNAGATEAREA attribute defined.
**WARN: (SOCLF-200):    Pin 'WR' in macro 'sram1024x8' has no ANTENNAGATEAREA attribute defined.
**WARN: (SOCLF-200):    Pin 'AD[0]' in macro 'sram1024x8' has no ANTENNAGATEAREA attribute defined.
**WARN: (SOCLF-200):    Pin 'AD[1]' in macro 'sram1024x8' has no ANTENNAGATEAREA attribute defined.
**WARN: (SOCLF-200):    Pin 'AD[2]' in macro 'sram1024x8' has no ANTENNAGATEAREA attribute defined.
**WARN: (SOCLF-200):    Pin 'AD[3]' in macro 'sram1024x8' has no ANTENNAGATEAREA attribute defined.
**WARN: (SOCLF-200):    Pin 'AD[4]' in macro 'sram1024x8' has no ANTENNAGATEAREA attribute defined.
**WARN: (SOCLF-200):    Pin 'AD[5]' in macro 'sram1024x8' has no ANTENNAGATEAREA attribute defined.
**WARN: (SOCLF-200):    Pin 'AD[6]' in macro 'sram1024x8' has no ANTENNAGATEAREA attribute defined.
**WARN: (SOCLF-200):    Pin 'EN' in macro 'sram1024x8' has no ANTENNAGATEAREA attribute defined.
**WARN: (SOCLF-200):    Pin 'AD[7]' in macro 'sram1024x8' has no ANTENNAGATEAREA attribute defined.
**WARN: (SOCLF-200):    Pin 'AD[8]' in macro 'sram1024x8' has no ANTENNAGATEAREA attribute defined.
**WARN: (SOCLF-200):    Pin 'DI[0]' in macro 'sram1024x8' has no ANTENNAGATEAREA attribute defined.
**WARN: (SOCLF-200):    Pin 'AD[9]' in macro 'sram1024x8' has no ANTENNAGATEAREA attribute defined.
**WARN: (SOCLF-200):    Pin 'CS' in macro 'sram1024x8' has no ANTENNAGATEAREA attribute defined.
**WARN: (SOCLF-200):    Pin 'RD' in macro 'sram1024x8' has no ANTENNAGATEAREA attribute defined.
**WARN: (SOCLF-200):    Pin 'DI[1]' in macro 'sram1024x8' has no ANTENNAGATEAREA attribute defined.
Power Planner/ViaGen version 7.1.45 promoted on 08/20/2008.
viaInitial starts at Mon Dec  7 12:31:47 2009
viaInitial ends at Mon Dec  7 12:31:47 2009
Reading netlist ...
Backslashed names will retain backslash and a trailing blank character.
Reading verilog netlist 'VERILOG/testvehikl.v'
*** Memory Usage v0.134.4.7 (Current mem = 195.734M, initial mem = 74.086M) ***
*** End netlist parsing (cpu=0:00:00.0, real=0:00:00.0, mem=195.7M) ***
Set top cell to testvehikl.
Reading common timing library '/Cadence/hk4.00/liberty/c35_3.3V/c35_CORELIB.lib' ...
**WARN: (TECHLIB-436):    Attribute 'max_fanout' on output/inout pin 'CO' of cell 'ADD21' is not defined in the library
**WARN: (TECHLIB-436):    Attribute 'max_fanout' on output/inout pin 'S' of cell 'ADD21' is not defined in the library
**WARN: (TECHLIB-436):    Attribute 'max_fanout' on output/inout pin 'CO' of cell 'ADD22' is not defined in the library
**WARN: (TECHLIB-436):    Attribute 'max_fanout' on output/inout pin 'S' of cell 'ADD22' is not defined in the library
**WARN: (TECHLIB-436):    Attribute 'max_fanout' on output/inout pin 'CO' of cell 'ADD31' is not defined in the library
**WARN: (TECHLIB-436):    Attribute 'max_fanout' on output/inout pin 'S' of cell 'ADD31' is not defined in the library
**WARN: (TECHLIB-436):    Attribute 'max_fanout' on output/inout pin 'CO' of cell 'ADD32' is not defined in the library
**WARN: (TECHLIB-436):    Attribute 'max_fanout' on output/inout pin 'S' of cell 'ADD32' is not defined in the library
**WARN: (TECHLIB-436):    Attribute 'max_fanout' on output/inout pin 'Q' of cell 'AOI210' is not defined in the library
**WARN: (TECHLIB-436):    Attribute 'max_fanout' on output/inout pin 'Q' of cell 'AOI211' is not defined in the library
**WARN: (TECHLIB-436):    Attribute 'max_fanout' on output/inout pin 'Q' of cell 'AOI2110' is not defined in the library
**WARN: (TECHLIB-436):    Attribute 'max_fanout' on output/inout pin 'Q' of cell 'AOI2111' is not defined in the library
**WARN: (TECHLIB-436):    Attribute 'max_fanout' on output/inout pin 'Q' of cell 'AOI2112' is not defined in the library
**WARN: (TECHLIB-436):    Attribute 'max_fanout' on output/inout pin 'Q' of cell 'AOI212' is not defined in the library
**WARN: (TECHLIB-436):    Attribute 'max_fanout' on output/inout pin 'Q' of cell 'AOI220' is not defined in the library
**WARN: (TECHLIB-436):    Attribute 'max_fanout' on output/inout pin 'Q' of cell 'AOI221' is not defined in the library
**WARN: (TECHLIB-436):    Attribute 'max_fanout' on output/inout pin 'Q' of cell 'AOI222' is not defined in the library
**WARN: (TECHLIB-436):    Attribute 'max_fanout' on output/inout pin 'Q' of cell 'AOI310' is not defined in the library
**WARN: (TECHLIB-436):    Attribute 'max_fanout' on output/inout pin 'Q' of cell 'AOI311' is not defined in the library
**WARN: (TECHLIB-436):    Attribute 'max_fanout' on output/inout pin 'Q' of cell 'AOI312' is not defined in the library
 read 241 cells in library 'c35_CORELIB'
Reading common timing library '/Cadence/hk4.00/liberty/c35_3.3V/c35_IOLIB_4M.lib' ...
No function defined for cell 'VDD3RP'. The cell will only be used for analysis.
No function defined for cell 'VDD3OP'. The cell will only be used for analysis.
No function defined for cell 'VDD3IP'. The cell will only be used for analysis.
No function defined for cell 'VDD3ALLP'. The cell will only be used for analysis.
No function defined for cell 'GND3RP'. The cell will only be used for analysis.
No function defined for cell 'GND3OP'. The cell will only be used for analysis.
No function defined for cell 'GND3IP'. The cell will only be used for analysis.
No function defined for cell 'GND3ALLP'. The cell will only be used for analysis.
**WARN: (SOCTS-299):    The pin A of cell VDD3ALLP in library c35_IOLIB_4M has been previously defined as a power pin. The timing information for this pin would not be loaded from the library.
**WARN: (SOCTS-299):    The pin A of cell GND3ALLP in library c35_IOLIB_4M has been previously defined as a ground pin. The timing information for this pin would not be loaded from the library.
 read 181 cells in library 'c35_IOLIB_4M'
Reading common timing library 'LIB/ablock.lib' ...
**WARN: (TECHLIB-9064):    Missing delay_model statement in the library (ABLOCK). generic_cmos delay model is assumed.
**WARN: (TECHLIB-9056):    (leakage_power_unit) not found in the library. Assuming (1nW)
 read 1 cells in library 'ABLOCK'
Reading common timing library 'LIB/sram256x8.lib' ...
**WARN: (TECHLIB-9064):    Missing delay_model statement in the library (sram256x8). generic_cmos delay model is assumed.
**WARN: (TECHLIB-9068):    Missing rise slew value for the path from pin EN to pin DO[7:0] in the cell sram256x8. Generating Paths with zero slew ....The data in the timing library is incomplete. This can result  in a loss of accuracy during delay calculation.
**WARN: (TECHLIB-9068):    Missing rise slew value for the path from pin EN to pin DO[7:0] in the cell sram256x8. Generating Path with zero Slew ....The data in the timing library is incomplete. This can result  in a loss of accuracy during delay calculation.
 read 1 cells in library 'sram256x8'
Reading common timing library 'LIB/sram1024x8.lib' ...
**WARN: (TECHLIB-9064):    Missing delay_model statement in the library (sram1024x8). generic_cmos delay model is assumed.
**WARN: (TECHLIB-9068):    Missing rise slew value for the path from pin EN to pin DO[7:0] in the cell sram1024x8. Generating Paths with zero slew ....The data in the timing library is incomplete. This can result  in a loss of accuracy during delay calculation.
**WARN: (TECHLIB-9068):    Missing rise slew value for the path from pin EN to pin DO[7:0] in the cell sram1024x8. Generating Path with zero Slew ....The data in the timing library is incomplete. This can result  in a loss of accuracy during delay calculation.
 read 1 cells in library 'sram1024x8'
*** End library_loading (cpu=0.03min, mem=11.8M, fe_cpu=0.09min, fe_mem=207.5M) ***
Starting recursive module instantiation check.
No recursion found.
*****NEW dbFlattenCell is used.
Flattening Cell testvehikl ...
*** Netlist is unique.
** info: there are 471 modules.
** info: there are 2711 stdCell insts.
** info: there are 50 Pad insts.
** info: there are 2 macros.
*** Memory Usage v0.134.4.7 (Current mem = 207.938M, initial mem = 74.086M) ***
Total number of combinational cells: 137
Total number of sequential cells: 89
Total number of tristate cells: 14
Total number of level shifter cells: 0
Total number of power gating cells: 0
Total number of isolation cells: 0
Total number of power switch cells: 0
Total number of pulse generator cells: 0
Total number of always on buffers: 0
Total number of retention cells: 0
List of usable buffers: BUF12 BUF15 BUF2 BUF6 BUF4 BUF8 CLKBU12 CLKBU15 CLKBU2 CLKBU6 CLKBU4 CLKBU8
Total number of usable buffers: 12
List of unusable buffers:
Total number of unusable buffers: 0
List of usable inverters: CLKIN1 CLKIN0 CLKIN12 CLKIN10 CLKIN15 CLKIN3 CLKIN2 CLKIN6 CLKIN4 CLKIN8 INV1 INV0 INV12 INV10 INV15 INV3 INV2 INV6 INV4 INV8
Total number of usable inverters: 20
List of unusable inverters:
Total number of unusable inverters: 0
List of identified usable delay cells: DLY12 DLY22 DLY32 DLY42
Total number of identified usable delay cells: 4
List of identified unusable delay cells:
Total number of identified unusable delay cells: 0
*info: set bottom ioPad orient R0
Reading IO assignment file "testvehikl.io" ...
Adjusting Core to Left to: 50.2000. Core to Bottom to: 50.9000.
Set Using Default Delay Limit as 1000.
Set Default Net Delay as 1000 ps.
Set Default Net Load as 0.5 pF.
Set Input Pin Transition Delay as 0.1 ps.
Reading Capacitance Table File /Cadence/hk4.00/cds/HK_C35/LEF/encounter/c35b4.capTable ...
Cap Table was created using First Encounter 06.20-s087_1.
Process name: C35B4.
**WARN: (SOCOPT-3465):    The buffer cells were automatically identified. The command setBufFootPrint is ignored. If you want to use this manual setting, rerun encounter with dbgGPSAutoCellFunction set to 0.
**WARN: (SOCOPT-3466):    The inverter cells were automatically identified. The command setInvFootPrint is ignored. If you want to use this manual setting, rerun encounter with dbgGPSAutoCellFunction set to 0.
**WARN: (SOCOPT-3467):    The delay cells were automatically identified. The command setDelayFootPrint is ignored. If you want to use this manual setting, rerun encounter with dbgGPSAutoCellFunction set to 0.
Set qxtech_file as /Cadence/hk4.00/cds/HK_C35/LEF/fireIce/c35b4.tch
Set qxlib_file as /Cadence/hk4.00/cds/HK_C35/LEF/fireIce/c35b4_libs
<CMD> fit
<CMD> setDrawView fplan
<CMD> getLayerPreference OA_MET4_pin -isVisible
<CMD> getLayerPreference OA_MET4_pin -isSelectable
<CMD> getLayerPreference OA_MET4_pin -color
<CMD> getLayerPreference OA_MET4_pin -stipple
<CMD> getLayerPreference OA_MET4_pin -stippleData
<CMD> getLayerPreference OA_MET4_obs -isVisible
<CMD> getLayerPreference OA_MET4_obs -isSelectable
<CMD> getLayerPreference OA_MET4_obs -color
<CMD> getLayerPreference OA_MET4_obs -stipple
<CMD> getLayerPreference OA_MET4_obs -stippleData
<CMD> getLayerPreference OA_MET4_geom -isVisible
<CMD> getLayerPreference OA_MET4_geom -isSelectable
<CMD> getLayerPreference OA_MET4_geom -color
<CMD> getLayerPreference OA_MET4_geom -stipple
<CMD> getLayerPreference OA_MET4_geom -stippleData
<CMD> getLayerPreference OA_MET4_text -isVisible
<CMD> getLayerPreference OA_MET4_text -isSelectable
<CMD> getLayerPreference OA_MET4_text -color
<CMD> getLayerPreference OA_MET4_text -stipple
<CMD> getLayerPreference OA_MET4_text -stippleData
<CMD> getLayerPreference OA_VIA3_pin -isVisible
<CMD> getLayerPreference OA_VIA3_pin -isSelectable
<CMD> getLayerPreference OA_VIA3_pin -color
<CMD> getLayerPreference OA_VIA3_pin -stipple
<CMD> getLayerPreference OA_VIA3_pin -stippleData
<CMD> getLayerPreference OA_VIA3_obs -isVisible
<CMD> getLayerPreference OA_VIA3_obs -isSelectable
<CMD> getLayerPreference OA_VIA3_obs -color
<CMD> getLayerPreference OA_VIA3_obs -stipple
<CMD> getLayerPreference OA_VIA3_obs -stippleData
<CMD> getLayerPreference OA_VIA3_geom -isVisible
<CMD> getLayerPreference OA_VIA3_geom -isSelectable
<CMD> getLayerPreference OA_VIA3_geom -color
<CMD> getLayerPreference OA_VIA3_geom -stipple
<CMD> getLayerPreference OA_VIA3_geom -stippleData
<CMD> getLayerPreference OA_VIA3_text -isVisible
<CMD> getLayerPreference OA_VIA3_text -isSelectable
<CMD> getLayerPreference OA_VIA3_text -color
<CMD> getLayerPreference OA_VIA3_text -stipple
<CMD> getLayerPreference OA_VIA3_text -stippleData
<CMD> getLayerPreference OA_MET3_pin -isVisible
<CMD> getLayerPreference OA_MET3_pin -isSelectable
<CMD> getLayerPreference OA_MET3_pin -color
<CMD> getLayerPreference OA_MET3_pin -stipple
<CMD> getLayerPreference OA_MET3_pin -stippleData
<CMD> getLayerPreference OA_MET3_obs -isVisible
<CMD> getLayerPreference OA_MET3_obs -isSelectable
<CMD> getLayerPreference OA_MET3_obs -color
<CMD> getLayerPreference OA_MET3_obs -stipple
<CMD> getLayerPreference OA_MET3_obs -stippleData
<CMD> getLayerPreference OA_MET3_geom -isVisible
<CMD> getLayerPreference OA_MET3_geom -isSelectable
<CMD> getLayerPreference OA_MET3_geom -color
<CMD> getLayerPreference OA_MET3_geom -stipple
<CMD> getLayerPreference OA_MET3_geom -stippleData
<CMD> getLayerPreference OA_MET3_text -isVisible
<CMD> getLayerPreference OA_MET3_text -isSelectable
<CMD> getLayerPreference OA_MET3_text -color
<CMD> getLayerPreference OA_MET3_text -stipple
<CMD> getLayerPreference OA_MET3_text -stippleData
<CMD> getLayerPreference OA_VIA2_pin -isVisible
<CMD> getLayerPreference OA_VIA2_pin -isSelectable
<CMD> getLayerPreference OA_VIA2_pin -color
<CMD> getLayerPreference OA_VIA2_pin -stipple
<CMD> getLayerPreference OA_VIA2_pin -stippleData
<CMD> getLayerPreference OA_VIA2_obs -isVisible
<CMD> getLayerPreference OA_VIA2_obs -isSelectable
<CMD> getLayerPreference OA_VIA2_obs -color
<CMD> getLayerPreference OA_VIA2_obs -stipple
<CMD> getLayerPreference OA_VIA2_obs -stippleData
<CMD> getLayerPreference OA_VIA2_geom -isVisible
<CMD> getLayerPreference OA_VIA2_geom -isSelectable
<CMD> getLayerPreference OA_VIA2_geom -color
<CMD> getLayerPreference OA_VIA2_geom -stipple
<CMD> getLayerPreference OA_VIA2_geom -stippleData
<CMD> getLayerPreference OA_VIA2_text -isVisible
<CMD> getLayerPreference OA_VIA2_text -isSelectable
<CMD> getLayerPreference OA_VIA2_text -color
<CMD> getLayerPreference OA_VIA2_text -stipple
<CMD> getLayerPreference OA_VIA2_text -stippleData
<CMD> getLayerPreference OA_MET2_pin -isVisible
<CMD> getLayerPreference OA_MET2_pin -isSelectable
<CMD> getLayerPreference OA_MET2_pin -color
<CMD> getLayerPreference OA_MET2_pin -stipple
<CMD> getLayerPreference OA_MET2_pin -stippleData
<CMD> getLayerPreference OA_MET2_obs -isVisible
<CMD> getLayerPreference OA_MET2_obs -isSelectable
<CMD> getLayerPreference OA_MET2_obs -color
<CMD> getLayerPreference OA_MET2_obs -stipple
<CMD> getLayerPreference OA_MET2_obs -stippleData
<CMD> getLayerPreference OA_MET2_geom -isVisible
<CMD> getLayerPreference OA_MET2_geom -isSelectable
<CMD> getLayerPreference OA_MET2_geom -color
<CMD> getLayerPreference OA_MET2_geom -stipple
<CMD> getLayerPreference OA_MET2_geom -stippleData
<CMD> getLayerPreference OA_MET2_text -isVisible
<CMD> getLayerPreference OA_MET2_text -isSelectable
<CMD> getLayerPreference OA_MET2_text -color
<CMD> getLayerPreference OA_MET2_text -stipple
<CMD> getLayerPreference OA_MET2_text -stippleData
<CMD> getLayerPreference OA_VIA1_pin -isVisible
<CMD> getLayerPreference OA_VIA1_pin -isSelectable
<CMD> getLayerPreference OA_VIA1_pin -color
<CMD> getLayerPreference OA_VIA1_pin -stipple
<CMD> getLayerPreference OA_VIA1_pin -stippleData
<CMD> getLayerPreference OA_VIA1_obs -isVisible
<CMD> getLayerPreference OA_VIA1_obs -isSelectable
<CMD> getLayerPreference OA_VIA1_obs -color
<CMD> getLayerPreference OA_VIA1_obs -stipple
<CMD> getLayerPreference OA_VIA1_obs -stippleData
<CMD> getLayerPreference OA_VIA1_geom -isVisible
<CMD> getLayerPreference OA_VIA1_geom -isSelectable
<CMD> getLayerPreference OA_VIA1_geom -color
<CMD> getLayerPreference OA_VIA1_geom -stipple
<CMD> getLayerPreference OA_VIA1_geom -stippleData
<CMD> getLayerPreference OA_VIA1_text -isVisible
<CMD> getLayerPreference OA_VIA1_text -isSelectable
<CMD> getLayerPreference OA_VIA1_text -color
<CMD> getLayerPreference OA_VIA1_text -stipple
<CMD> getLayerPreference OA_VIA1_text -stippleData
<CMD> getLayerPreference OA_MET1_pin -isVisible
<CMD> getLayerPreference OA_MET1_pin -isSelectable
<CMD> getLayerPreference OA_MET1_pin -color
<CMD> getLayerPreference OA_MET1_pin -stipple
<CMD> getLayerPreference OA_MET1_pin -stippleData
<CMD> getLayerPreference OA_MET1_obs -isVisible
<CMD> getLayerPreference OA_MET1_obs -isSelectable
<CMD> getLayerPreference OA_MET1_obs -color
<CMD> getLayerPreference OA_MET1_obs -stipple
<CMD> getLayerPreference OA_MET1_obs -stippleData
<CMD> getLayerPreference OA_MET1_geom -isVisible
<CMD> getLayerPreference OA_MET1_geom -isSelectable
<CMD> getLayerPreference OA_MET1_geom -color
<CMD> getLayerPreference OA_MET1_geom -stipple
<CMD> getLayerPreference OA_MET1_geom -stippleData
<CMD> getLayerPreference OA_MET1_text -isVisible
<CMD> getLayerPreference OA_MET1_text -isSelectable
<CMD> getLayerPreference OA_MET1_text -color
<CMD> getLayerPreference OA_MET1_text -stipple
<CMD> getLayerPreference OA_MET1_text -stippleData
<CMD> getLayerPreference OA_CONT_pin -isVisible
<CMD> getLayerPreference OA_CONT_pin -isSelectable
<CMD> getLayerPreference OA_CONT_pin -color
<CMD> getLayerPreference OA_CONT_pin -stipple
<CMD> getLayerPreference OA_CONT_pin -stippleData
<CMD> getLayerPreference OA_CONT_obs -isVisible
<CMD> getLayerPreference OA_CONT_obs -isSelectable
<CMD> getLayerPreference OA_CONT_obs -color
<CMD> getLayerPreference OA_CONT_obs -stipple
<CMD> getLayerPreference OA_CONT_obs -stippleData
<CMD> getLayerPreference OA_CONT_geom -isVisible
<CMD> getLayerPreference OA_CONT_geom -isSelectable
<CMD> getLayerPreference OA_CONT_geom -color
<CMD> getLayerPreference OA_CONT_geom -stipple
<CMD> getLayerPreference OA_CONT_geom -stippleData
<CMD> getLayerPreference OA_CONT_text -isVisible
<CMD> getLayerPreference OA_CONT_text -isSelectable
<CMD> getLayerPreference OA_CONT_text -color
<CMD> getLayerPreference OA_CONT_text -stipple
<CMD> getLayerPreference OA_CONT_text -stippleData
<CMD> getLayerPreference OA_POLY2_pin -isVisible
<CMD> getLayerPreference OA_POLY2_pin -isSelectable
<CMD> getLayerPreference OA_POLY2_pin -color
<CMD> getLayerPreference OA_POLY2_pin -stipple
<CMD> getLayerPreference OA_POLY2_pin -stippleData
<CMD> getLayerPreference OA_POLY2_obs -isVisible
<CMD> getLayerPreference OA_POLY2_obs -isSelectable
<CMD> getLayerPreference OA_POLY2_obs -color
<CMD> getLayerPreference OA_POLY2_obs -stipple
<CMD> getLayerPreference OA_POLY2_obs -stippleData
<CMD> getLayerPreference OA_POLY2_geom -isVisible
<CMD> getLayerPreference OA_POLY2_geom -isSelectable
<CMD> getLayerPreference OA_POLY2_geom -color
<CMD> getLayerPreference OA_POLY2_geom -stipple
<CMD> getLayerPreference OA_POLY2_geom -stippleData
<CMD> getLayerPreference OA_POLY2_text -isVisible
<CMD> getLayerPreference OA_POLY2_text -isSelectable
<CMD> getLayerPreference OA_POLY2_text -color
<CMD> getLayerPreference OA_POLY2_text -stipple
<CMD> getLayerPreference OA_POLY2_text -stippleData
<CMD> getLayerPreference OA_PPLUS_pin -isVisible
<CMD> getLayerPreference OA_PPLUS_pin -isSelectable
<CMD> getLayerPreference OA_PPLUS_pin -color
<CMD> getLayerPreference OA_PPLUS_pin -stipple
<CMD> getLayerPreference OA_PPLUS_pin -stippleData
<CMD> getLayerPreference OA_PPLUS_obs -isVisible
<CMD> getLayerPreference OA_PPLUS_obs -isSelectable
<CMD> getLayerPreference OA_PPLUS_obs -color
<CMD> getLayerPreference OA_PPLUS_obs -stipple
<CMD> getLayerPreference OA_PPLUS_obs -stippleData
<CMD> getLayerPreference OA_PPLUS_geom -isVisible
<CMD> getLayerPreference OA_PPLUS_geom -isSelectable
<CMD> getLayerPreference OA_PPLUS_geom -color
<CMD> getLayerPreference OA_PPLUS_geom -stipple
<CMD> getLayerPreference OA_PPLUS_geom -stippleData
<CMD> getLayerPreference OA_PPLUS_text -isVisible
<CMD> getLayerPreference OA_PPLUS_text -isSelectable
<CMD> getLayerPreference OA_PPLUS_text -color
<CMD> getLayerPreference OA_PPLUS_text -stipple
<CMD> getLayerPreference OA_PPLUS_text -stippleData
<CMD> getLayerPreference OA_NPLUS_pin -isVisible
<CMD> getLayerPreference OA_NPLUS_pin -isSelectable
<CMD> getLayerPreference OA_NPLUS_pin -color
<CMD> getLayerPreference OA_NPLUS_pin -stipple
<CMD> getLayerPreference OA_NPLUS_pin -stippleData
<CMD> getLayerPreference OA_NPLUS_obs -isVisible
<CMD> getLayerPreference OA_NPLUS_obs -isSelectable
<CMD> getLayerPreference OA_NPLUS_obs -color
<CMD> getLayerPreference OA_NPLUS_obs -stipple
<CMD> getLayerPreference OA_NPLUS_obs -stippleData
<CMD> getLayerPreference OA_NPLUS_geom -isVisible
<CMD> getLayerPreference OA_NPLUS_geom -isSelectable
<CMD> getLayerPreference OA_NPLUS_geom -color
<CMD> getLayerPreference OA_NPLUS_geom -stipple
<CMD> getLayerPreference OA_NPLUS_geom -stippleData
<CMD> getLayerPreference OA_NPLUS_text -isVisible
<CMD> getLayerPreference OA_NPLUS_text -isSelectable
<CMD> getLayerPreference OA_NPLUS_text -color
<CMD> getLayerPreference OA_NPLUS_text -stipple
<CMD> getLayerPreference OA_NPLUS_text -stippleData
<CMD> getLayerPreference OA_POLY1_pin -isVisible
<CMD> getLayerPreference OA_POLY1_pin -isSelectable
<CMD> getLayerPreference OA_POLY1_pin -color
<CMD> getLayerPreference OA_POLY1_pin -stipple
<CMD> getLayerPreference OA_POLY1_pin -stippleData
<CMD> getLayerPreference OA_POLY1_obs -isVisible
<CMD> getLayerPreference OA_POLY1_obs -isSelectable
<CMD> getLayerPreference OA_POLY1_obs -color
<CMD> getLayerPreference OA_POLY1_obs -stipple
<CMD> getLayerPreference OA_POLY1_obs -stippleData
<CMD> getLayerPreference OA_POLY1_geom -isVisible
<CMD> getLayerPreference OA_POLY1_geom -isSelectable
<CMD> getLayerPreference OA_POLY1_geom -color
<CMD> getLayerPreference OA_POLY1_geom -stipple
<CMD> getLayerPreference OA_POLY1_geom -stippleData
<CMD> getLayerPreference OA_POLY1_text -isVisible
<CMD> getLayerPreference OA_POLY1_text -isSelectable
<CMD> getLayerPreference OA_POLY1_text -color
<CMD> getLayerPreference OA_POLY1_text -stipple
<CMD> getLayerPreference OA_POLY1_text -stippleData
<CMD> getLayerPreference OA_DIFF_pin -isVisible
<CMD> getLayerPreference OA_DIFF_pin -isSelectable
<CMD> getLayerPreference OA_DIFF_pin -color
<CMD> getLayerPreference OA_DIFF_pin -stipple
<CMD> getLayerPreference OA_DIFF_pin -stippleData
<CMD> getLayerPreference OA_DIFF_obs -isVisible
<CMD> getLayerPreference OA_DIFF_obs -isSelectable
<CMD> getLayerPreference OA_DIFF_obs -color
<CMD> getLayerPreference OA_DIFF_obs -stipple
<CMD> getLayerPreference OA_DIFF_obs -stippleData
<CMD> getLayerPreference OA_DIFF_geom -isVisible
<CMD> getLayerPreference OA_DIFF_geom -isSelectable
<CMD> getLayerPreference OA_DIFF_geom -color
<CMD> getLayerPreference OA_DIFF_geom -stipple
<CMD> getLayerPreference OA_DIFF_geom -stippleData
<CMD> getLayerPreference OA_DIFF_text -isVisible
<CMD> getLayerPreference OA_DIFF_text -isSelectable
<CMD> getLayerPreference OA_DIFF_text -color
<CMD> getLayerPreference OA_DIFF_text -stipple
<CMD> getLayerPreference OA_DIFF_text -stippleData
Encounter terminated by internal (SEGV) error/signal...
*** Stack trace:
/Cadence/soc7.10/tools.lnx86/fe/bin/32bit/encounter(syStackTrace+0x146)[0xd0b7e3f]
/Cadence/soc7.10/tools.lnx86/fe/bin/32bit/encounter[0x8cf2ce8]
[0xffffe600]
/Cadence/soc7.10/tools.lnx86/fe/bin/32bit/encounter(_Z14winTextExtentsP7winsWinP9winsLayerPcPiS4_S4_+0x75)[0xcf3c04d]
/Cadence/soc7.10/tools.lnx86/fe/bin/32bit/encounter(_Z16winDrawTextInBoxP7winsWinP9winsLayerPcP6sysBoxici+0x23b)[0xcf78371]
/Cadence/soc7.10/tools.lnx86/fe/bin/32bit/encounter[0xcf58fe4]
/Cadence/soc7.10/tools.lnx86/fe/bin/32bit/encounter[0xcf56757]
/Cadence/soc7.10/tools.lnx86/fe/bin/32bit/encounter(_Z20winViewListIterationP7winsWini+0xf4)[0xcf3f95a]
/Cadence/soc7.10/tools.lnx86/fe/bin/32bit/encounter(_Z13winDbDrawViewP7winsWin+0x257)[0xcf66711]
/Cadence/soc7.10/tools.lnx86/fe/bin/32bit/encounter(_Z10winDisplayP7winsWin+0x9a)[0xcf39df0]
/Cadence/soc7.10/tools.lnx86/fe/bin/32bit/encounter[0xcf3d138]
/Cadence/soc7.10/tools.lnx86/fe/bin/32bit/encounter(TclServiceIdle+0x59)[0xdec5ed9]
/Cadence/soc7.10/tools.lnx86/fe/bin/32bit/encounter(Tcl_DoOneEvent+0x16e)[0xdeb686e]
/Cadence/soc7.10/tools.lnx86/fe/bin/32bit/encounter(Tcl_AppInit+0x453)[0x8cd79ef]
/Cadence/soc7.10/tools.lnx86/fe/bin/32bit/encounter(Tk_MainEx+0x25e)[0xddd938e]
/Cadence/soc7.10/tools.lnx86/fe/bin/32bit/encounter(_Z7fe_mainiPPc+0x43e)[0x8cd7e3a]
/Cadence/soc7.10/tools.lnx86/fe/bin/32bit/encounter(main+0x79)[0x8cd811d]
/lib/libc.so.6(__libc_start_main+0xdc)[0x99ce9c]
/Cadence/soc7.10/tools.lnx86/fe/bin/32bit/encounter[0x8cd74b1]
               pstack
Thread 4 (Thread 0xf6cd6b90 (LWP 9317)):
#0  0xffffe410 in __kernel_vsyscall ()
#1  0x00ae1f86 in nanosleep () from /lib/libpthread.so.0
#2  0x09ee7f80 in rdaiLicRecheck ()
#3  0x00ada5ab in start_thread () from /lib/libpthread.so.0
#4  0x00a58cfe in clone () from /lib/libc.so.6
Thread 3 (Thread 0xf62d5b90 (LWP 9318)):
#1  0x00a518c1 in select () from /lib/libc.so.6
#2  0x0ded904c in NotifierThreadProc ()
Thread 2 (Thread 0xf58d4b90 (LWP 9319)):
#1  0x00ae28de in do_sigwait () from /lib/libpthread.so.0
#2  0x00ae297f in sigwait () from /lib/libpthread.so.0
#3  0x08cf3091 in ctrlCHandle ()
#4  0x00ada5ab in start_thread () from /lib/libpthread.so.0
#5  0x00a58cfe in clone () from /lib/libc.so.6
Thread 1 (Thread 0xf7b316c0 (LWP 9267)):
#1  0x00a184cb in waitpid () from /lib/libc.so.6
#2  0x009bd07b in do_system () from /lib/libc.so.6
#3  0x009bd412 in system () from /lib/libc.so.6
#4  0x00ae2b3d in system () from /lib/libpthread.so.0
#5  0x0d0b7ea6 in syStackTrace ()
#6  0x08cf2ce8 in rdaiErrorHandler ()
#7  <signal handler called>
#8  0x001395ce in XTextExtents () from /usr/lib/libX11.so.6
#9  0x0cf3c04d in winTextExtents ()
#10 0x0cf78371 in winDrawTextInBox ()
#11 0x0cf58fe4 in winiHInstDraw ()
#12 0x0cf56757 in winiHInstIter ()
#13 0x0cf3f95a in winViewListIteration ()
#14 0x0cf66711 in winDbDrawView ()
#15 0x0cf39df0 in winDisplay ()
#16 0x0cf3d138 in winiTkDisplay ()
#17 0x0dec5ed9 in TclServiceIdle ()
#18 0x0deb686e in Tcl_DoOneEvent ()
#19 0x08cd79ef in Tcl_AppInit ()
#20 0x0ddd938e in Tk_MainEx ()
#21 0x08cd7e3a in fe_main ()
#22 0x08cd811d in main ()
                gdb
Using: gdb
[Thread debugging using libthread_db enabled]
[New Thread 0xf7b316c0 (LWP 9267)]
[New Thread 0xf58d4b90 (LWP 9319)]
[New Thread 0xf62d5b90 (LWP 9318)]
[New Thread 0xf6cd6b90 (LWP 9317)]
The program is running.  Quit anyway (and detach it)? (y or n) [answered Y; input not from terminal]
9267: No such process
  • CriGri
     Hi!
     I have to mention that i work with my windows 7 (64bit) notebook on a server. With my notebook i get the mentioned error. I just tried to start encounter with a Win XP (32bit)notebook and it works!
     Do you have an idea why this is so? I thought that it doesn't matter if i work on a server.
    Kind regards
  • anschrox24
    anschrox24 over 15 years ago
     This is a major concern,.might as well contact the admin...
