  3. samenet spacing violations
  • Subscribers 94
  • Views 15453
Priyatham
Priyatham over 15 years ago
After routing using the NanoRoute - when I run a verifyGeometry I get some samenet spacing violations - all on VIAs. When I run verifyGeometry with -allowDiffCellViols, all these violations are cleared. So someone advised that its probably not the routing that's causing the violations but the cell design. But those are the standard cells for First Encounter and I have no clue why they might be causing the problem. Any advise on this and how to resolve this issue would be a great help.
Priyatham.
  • RajaK
    RajaK over 15 years ago
    Hi Priyatham, Can you run verifyGeometry before nanoroute? This should isolate the problem to whether the violations are coming due to routing. Also note that one of the rules for std cell design is that any cell should be able to abut any cell with legal orientation and not cause a DRC violation. Thanks
  • Priyatham
     Thanks RajaK for your suggestion, I have resolved that problem. Your guess is right, the standard cells I was using were laid out in a way that they couldn't be abutted without DRC violations. So the DRCs were actually not because of the Routing, but because of the Placement itself. To Resolve that issue I set the following parameter to true before doing the placement:
    setPlaceMode -padForPinNearBorder {true | false}
    Adds padding to a cell if any signal pin is near enough to the border to cause DRC violations with any metal geometry.
    Default: false
    That solved the issue. Thankyou for the reply though.
    Priyatham.
  • meherravi
    meherravi over 12 years ago
     hi Priyatham,
                In 45nm and lower technologies, there is a foundry rule defined as never two cells of different threshold voltages should be abutted .i.e LVT, HVT, or RVT (any of the two combinations should not be abutted in 45nm or lower technologies)
    Ravikiran
  • Kari
    Kari over 11 years ago
    for anyone reading this, i just want to say that last statement is not generally true. there may be some process or library with that requirement, but I have not come across it.
