  3. How to make SoC Encounter export Verilog with added VDD...
  • Subscribers 93
  • Views 1941
How to make SoC Encounter export Verilog with added VDD/VSS pins
LogicWizard
LogicWizard over 15 years ago
Hi, folks,
After Design Compiler, the gate-level Verilog does not have any VDD/VSS pins for each cell, e.g.
INVD1 U1 (.A(n1), .Z(n2))
Then this Verilog is imported to SoC Encounter. After P&R, is there any way to make SoC Encounter export final Verilog with added VDD/VSS pins for each cell?
INVD1 U1(.A(n1), .Z(n2), .VDD(VDD), .VSS(VSS))
For LEF file VDD/VSS are listed for each cell, but while .lib does not have them.
Please help.
  • KVBABU
    KVBABU over 15 years ago
    Hi ,
    Try to save netlist with the following command :
    saveNetlist -includePowerGround
  • Vishnu Chada
    Vishnu Chada over 15 years ago
    Just to add to the response, do not forget to perform globalNetConnections before you write out the netlist with power and ground. --Vishnu
