  3. crosstalk delta delay in report_timing format
  • Subscribers 92
  • Views 16662
KVBABU
KVBABU over 15 years ago
Hi All,
I  wants crosstalk delta delay to be reported  . So what paramter i need to specify in
set_global report_timing_format . Or else is there any other way to report this in encounter:
Can you please help me on this .
VB
  • Kari
    Kari over 15 years ago
     Add incr_delay to  your report_timing_format.
  • grunertj
    grunertj over 14 years ago
    Is there a way to have incremental delays reported in the same session for setup and hold violations?
    report_timing -late -to <endpoint>
    report_timing -early -to <endpoint>
     I'd like to see correct incremental delays on both paths (setup and hold).
     How do I setup soce to do so?
    Jens
  • Kari
    Kari over 14 years ago
     timeDesign -si
    timeDesign -si -hold
