  3. how to automatically add connections to global nets in ...
  • Subscribers 92
  • Views 15287
how to automatically add connections to global nets in Encounter
Greatrebel
Greatrebel over 15 years ago
I found that it was very boring to add every pin and net into the connection list to connect global nets. Is there any way which can faciliate
this operation?
Thanks in advance
  • Kari
    Kari over 15 years ago
     You're taking advantage of wildcards, right?
    globalNetConnect VDD   -type pgpin -pin VDD  -inst * -all -override
  • mikhail
    mikhail over 15 years ago
    In case you have a multysupply/multivoltage design you need to take care about CPF. For a rest designs you typically need just few global net connections (for core instances and pads). So, I suppose that using wildcard solution shown by Kari is suitable for most of designs.
  • Greatrebel
    Thanks for both of you!
