  3. CTS and dontTouch Nets/instances
  • Subscribers 91
  • Views 4454
Rajesh Vembu
Rajesh Vembu over 15 years ago
 I have a couple of questions on how CTS handles dontTouch nets/instances.
1. Assume there are pre-inserted buffers/inverters in the clock path without a FIXED attribute. However the nets belonging to them have a dontTouch attribute set.
"deleteClockTree -all"  deletes the existing buffers/inverters in the clock path if there's no FIXED attribute on them, thereby overriding the dontTouch on the nets. Is this the right behavior?
a. Does deleteClockTree honor only the dontTouch attribute on the instance and not the nets ?
b. is there a way to instruct the deleteClockTree command to honor dontTouchNets?
2.  Will Clock Tree be synthesized if there are "DontTouch Nets" in the clock path?
If not, how to fix transition/delay violations on those nets?
  • Kari
    Kari over 15 years ago
     If you want pre-existing buffers/inverters to not be deleted by deleteClockTree, then they must be marked FIXED.
    I had accidentally put a set_dont_touch on my clock net and CTS would not build a tree, so you probably need to remove the set_dont_touch on your clock nets.
  • Rajesh Vembu
     Kari,
    Thanks for the information. CTS does honor dontTouch nets while synthesizing the clocks.
    However, the "CASCADE" buffers seems to be inserted even on the "DontTouch" nets. Is this a bug or a feature?
    Is there a way to avoid it, other than removing the clock root from ClkGroup?
    Regards
    Rajesh
  • Kari
     Hi Rajesh,
     I don't think CTS should add anything to a dont_touch net. Make sure that your dont_touch constraints are in fact being read in correctly. If they are, then a CCR may be in order. Are you using the latest version of EDI?
     - Kari
