  3. CTS; Booster - Buffer
  • Subscribers 92
  • Views 1019
Yemelya
Yemelya over 15 years ago
The clock tree from CTS starts with very long unbuffered wire from the clock pin. How can I instruct the CTS to locate strong buffer next to the pin?
Thank You,
-Boris
  • Kari
    Kari over 15 years ago
     Use the command
    AddDriverCell BUFX24
    in your clock spec file, where BUFX24 is the name of the buffer you want to use.
  • Yemelya
    Kari, thank you very much for your help.
