  3. settings to not echo expanded command lines in log/log.cmd...
  • Subscribers 92
  • Views 2211
settings to not echo expanded command lines in log/log.cmd file
prathima
prathima over 15 years ago
Is there any setting to avoid echoing of expanded command lines in log/log.cmd file?
For example,
I  am calling a procedure which has the following command:
set names [dbGet [dbGet -regexp -u -p top.insts.cell.name ${ptrn}].name]
The log file/ cmd.log file has the command " [dbGet -regexp -u -p top.insts.cell.name ${ptrn}]" completely expanded to:
dbGet {0x2abc53c960 0x2abc53c8c8........ 0x2abc53c798.name}
Because of this the logfiles are bulky and difficult to parse. Please let me know if there is any way to avoid this?
Thanks & Regards,
Prathima.
  • Kari
    Kari over 15 years ago
     I don't think there is any way to change this.
  • prathima
    Hi Kari,
    So there is no way to redirect the output of dbGet to /tmp?
    Prathima.
  • wally1
    wally1 over 15 years ago
     Hi Prathima, Have you seen the following solution article on how to disable the logging of commands?
     http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11645174
     I think this may provide what you need.
  • Kari
     Thanks for posting this!
  • prathima
    Hi Wally,
    Thanks a lot for pointing me to this article. It's the perfect solution for my problem!! But unfortunately I wouldn't be able to use as I am using 8.1 version.
    Regards, Prathima.
