  3. delay vs buffer cells
  • Subscribers 92
  • Views 15348
SINGI
SINGI over 15 years ago
 I have one question
How does encounter recognisez whether a cell is of delay type or buff. In my case BuffD1 is buffer where as BufD8 is delay.
######encounter.log
List of usable buffers: BUFD1
List of identified usable delay cells: BUFD9
I checked Lef files and the lib files but no where it is mentioned as any particular type. I am confused on how encounter deffentiates them. In all the inputs I have given to encounter command of type buffer/delay is not mentioned any where
Please give some exp.
BR
Sing
  • wally1
    wally1 over 15 years ago
    Hi Sing,
    Encounter uses an internal algorithm which looks at the characteristics of the cells from the timing library to sort buffers from delay cells. The following solution explains how you can use the footprint file to modify this:
     http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11125148
    The algorithm works well but if you think it can be improved please open a Service Request through http://support.cadence.com and we look at your specific case.
    Brian
