  3. Problem with ELC tool
  • Replies 8
  • Subscribers 96
  • Views 15656
tungthanhhoang
tungthanhhoang over 15 years ago
I use ELC to characterize a standard cell library. I used SPECTRE simulator with TSMC model (target to Spectre). When I run ELC, there is a error message that apprears when db_spice command is run
 Reading SUBCKT:NMOSCAP
[ERROR(db_prepare)] spice syntax error: NMOSCAP : redefinition of the subckt [ file = ./model/./tsmcxxxx.scs, #line = 122760 ]
 => subckt nmoscap ng nds
I had checked postes in forum and found out there is a suggestion for the case of using HSPICE simulator
www.cadence.com/.../20163.aspx
I followed that solution but error is remained
 I also check my TSMC model file for SPECTRE simulator and it works fine however it seems that ELC can not successfully load my model.
 Is there anybody having the same problem and a solution for it ?
 Kind regards
 /T
  • Keeshik
    Keeshik over 15 years ago
    According to the message you copied, there are multiple definitions for the subckt NMOSCAP. Please check your spice input data and remove redundant one. ELC has own syntax checking, which is not necessary identical to the Spectre syntax checking. I mean ELC may report ERROR although a standalone Spectre can pass the syntax problem.
    Keeshik
  • Thodoros
    Thodoros over 13 years ago
     Dear tungthanhhoang,
    I am experiencing the same problem with the UMC65ll technology. How can we work around the redefinition of the model?
    I tryed to use subsets of the model file but the simulation allways fails as it cannot find model parameters like tox.
    Thanks in advance for your help,
    Thodoros
  • Willvlsi
    Willvlsi over 11 years ago
    Hi, Thodoros I'm facing same problem with you. Do you solved this problem? How?
  • Thodoros
    Thodoros over 11 years ago
    I sovled it a long time ago.
    How do you define the model in the elccfg?
  • Willvlsi
    just as MODEL=" path/model_name.scs" please check my post for details http://www.cadence.com/Community/forums/p/28521/1331263.aspx#1331263 Thx!
  • Thodoros
    Also define the section to use next to the model.
    Something like
     MODEL=" path/model_name.scs" section_name
    section name could be [tt | ff | ss]_string.
    Tell me if this helps. It did the job for my umc std lib.
     Thodoros.
  • Willvlsi
    I think we may faced different problems.
    Mine is the ELC do not recognizing the parameter command in model file.
    Still thank you for your advice!
  • vuong
    vuong over 11 years ago
