  3. command line arguments into RC tcl scripts
  • Subscribers 93
  • Views 17220
kasyab
kasyab over 15 years ago
  Is it possible to pass command line arguments (similar to argv in normal tcl scripts) into RC tcl scripts?
What I understand is that, when  RC is invoked with a '-f' option it invokes the script in its own shell and then invokes the script specified. Supposing that for example, within this shell I wish to choose a list of libraries from three sets of libraries I have access to, through an option passed at runtime, how will I achieve this?
The intention is to create fairly generic synthesis scripts for an environment controlled by make targets.
Thanks in advance,
Kasyab
  • kazad
    kazad over 15 years ago
    Hi Kasyab
    You can pass the library list and other variables from Makefile into RC. Here are the steps:
    In you Makefile:
    lib_dir = xx/yy/zz
    slow_lib_list = ${shell ls -1 ${lib_dir}/std_slow.lib} \
                    ${shell ls -1 ${lib_dir}/macro_slow.lib}
    fast_lib_list = ${shell ls -1 ${lib_dir}/std_fast.lib} \
                    ${shell ls -1 ${lib_dir}/macro_fast.lib}
    typ_lib_list = ${shell ls -1 ${lib_dir}/std_typ.lib} \
                    ${shell ls -1 ${lib_dir}/macro_typ.lib}
    In RC synthesis script:
    set_attribute library $env(slow_lib_list)
    Hope this helps.
    Khandaker
  • grasshopper
    grasshopper over 15 years ago
     Any reason you cannot do
    rc -f script.tcl -e 'set libFiles {slow_as_molasses.lib honking_memory.lib}'
    Diego-
  • grasshopper
    rc -f script.tcl -ex 'set libFiles {slow_as_molasses.lib honking_memory.lib}'
    later,
    gh-
  • kasyab
     Thanks grashopper and kazad. I figured out a solution similar to the one proposed by kazad. That was the one more suitable to my needs.
    grashopper: I was looking for ways to switch entire library sets and as far as I know, the way to do this was by switching the search path for those libraries at runtime. I may not have understood your solution completely, but what I understood from it was that you set all the variables through the '-ex' switch; this would have proved quite tedious in my case.
