  3. collection
  • Subscribers 92
  • Views 13707
collection
HariKrishnaAMD
HariKrishnaAMD over 15 years ago
 hi all,
I am getting information about only one path using report_timing -collection.
how can i get information about many paths using report_timing -collection
  • BobD
    BobD over 15 years ago
    Have a look at the comments section of this blog entry -- it covers that subject I believe:
    /blogs/di/archive/2010/07/23/programatically-capturing-cell-delay-in-the-encounter-digital-implementation-system.aspx
    If you have multiple paths in the collection you can iterate through them with "foreach_in_collection". For example of you wanted to print out how many timing points were in each of the first 10 worst paths in the design you could do this:
    set c [report_timing -max_points 10 -collection]
    set count 1
    foreach_in_collection path $c {
    set timing_points [get_property $path timing_points]
    puts "Path $count contains [sizeof_collection $timing_points] timing point(s)"
    incr count
  • HariKrishnaAMD
     hi bob,
            thanx a lot...I think it will do for me
