  3. Command for getting only the si delay
  • Subscribers 93
  • Views 13708
ssuhas
ssuhas over 15 years ago
I wanted to know the si delay added after performing SI analysis.
Can anyone let me know the command to get only the SI delay of the nets
  • Kari
    Kari over 15 years ago
    To see the incremental delay from SI analysis, set up your report format to include it:
    set_global report_timing_format {instance cell arc delay incr_delay arrival load slew fanout pin_location}
    Then, when you do report_timing or timeDesign, you'll have an incr_delay column. If you want the net and component delay split out on separate lines, you'll neet to use report_timing -net. Otherwise, the default is to combine the component and net delay into one line.
    Hope that helps,
    - Kari
  • Martinage
    Martinage over 15 years ago
    You can also use the  timing Tcl API to query the net arcs directly for the delta delay values:
        set delta_delay_max_rise  [get_property [get_arcs -from U1/Y -to U2/A] delta_delay_max_rise]
    There are similar properties for min delays and for falling delays.  Refer to the get_property command
    which is documented under the "Advanced Timing Tcl Scripting Commands" in the EDI or ETS
    Command Reference document.
    Note: Queries on arc delays are not yet MMMC aware - you cannot use the get_property -view qualifier
             yet to query on a view-specific basis.
    - Ed
