  3. Why LVS Errors by SOC Encounter ?
  • Subscribers 92
  • Views 14285
IEEE Chairman
IEEE Chairman over 15 years ago
 When I used the command "v2lvs" to transfer a netlist from SOC Encounter to a spice file, there were warnings :
"Warning: Duplicate port/net name "...." found in module "......" while doing case-insensitive lookup ."
I just ignored it , and did a LVS check . But the final result is :
Error:    Different numbers of nets.
Error:    Connectivity errors.
Warning:  Ambiguity points were found and resolved arbitrarily.
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
 Ports:             10        12    *
 Nets:             140       131    *
NUMBERS OF OBJECTS AFTER TRANSFORMATION
 Ports:             10        10
 Nets:             140       129    *
It passed  a DRC check , but failed in a LVS check. I don't know if the failure reason is previous warnings . I have no idea why a netlist from SOCE couldn't pass a LVS check . After all the LVS check just check the design in different forms ,a netlist & a gds ,from the same SOCE design.
However my  same flow is OK for other designs.
Could anyone help me?
  • IEEE Chairman
     I found that it was because some tiehi pins didn't connect to VDD.
