  3. #WARNING (NRCM-90) nanoroute aborted: invalid memory reference...
  • Subscribers 92
  • Views 13671
Sundarsan
Sundarsan over 15 years ago
Nano route crashes after reporting below warning message,
I tried both 32bit and 64bit options in nanoroute. Both of them reporting same warning message and crashes.
It will be a great help, if u share ur experience in solving this problem.
Sundar
  • Kari
    Kari over 15 years ago
     It's hard to say what the problem might be without access to your data, but just a couple of general tips:
    Sometimes you'll see a strange nanoroute crash if something is wrong with the placement. Run checkPlace and verify that everything is ok with your placement.
    Go through the entire log file and look for any ERRORs or other WARNINGs. Sometimes a problem may have occurred earlier in the flow that didn't cause a crash, but can cause issues later on.
