  3. Encounter - placeBondPad
  • Subscribers 92
  • Views 1447
Yemelya
Yemelya over 15 years ago
The following command doesn’t bring any results. Am I using this wrong way or should I use another encounter command?
placeBondPad -ioInstName i_pads/i_ddd_pad/i_pad12_digin_pulldown \
             -pad PAD80L \
             -pinName PAD \
             -position M \
             -fix
Thank you very much,
-Boris
  • wally1
    wally1 over 15 years ago
    Hi Boris,
    Can you explain what you are trying to do? If you're trying the place the bond pad over the IO cell driver the following solution may help:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11488340
    Brian
  • Yemelya
    Brian, thank you very much!
    Best regards,
    -Boris
