  3. List all cells in fanout/fanin cone of a node
  • Subscribers 92
  • Views 10057
ssuhas
ssuhas over 15 years ago
I wanted  know how do we list all cells in fanout/fanin cone of a node in encounter.
Do we have any command to get the above else can i get to the way to start of writing the tcl script for the above.
  • BobD
    BobD over 15 years ago
    The all_fanout and all_fanin commands are available in Encounter for this.  For example:
    encounter 22> all_fanout -only_cells -from [get_pins DTMF_INST/TDSP_CORE_INST/TDSP_CORE_GLUE_INST/i_955/Y]
    0x83
    Let us know if we could help applying those commands to your scenario.
    Hope this helps,
    Bob
  • ssuhas
    Hi bob,
    It did help me out but I also wanted to get to know how do we find the fanin and fanout nets for the given cell.
    The commands mentioned by you gives me the the cells to which the fanin and fanout nets are connected to.But I wanted the names of fanin and fanout nets too.
  • BobD
    There may be an easier way to do this, but you could loop through each of the pins in the fanout cone and append the connected net to a list:
    set nets {}
    foreach_in_collection pin [all_fanout -from [get_ports din[14]]] {
      set net [all_connected $pin]
      set netName [get_property $net hierarchical_name]
      if {[lsearch $nets $netName] == -1} {
        lappend nets $netName
    Puts "Found [llength $nets] net(s):"
    Puts "$nets"
    Example:
    Found 17 net(s):
    {din[14]} {din[14]} n_4744 {din[14]} n_4840 {din[14]} n_4936 {din[14]} n_5032 {din[14]} n_5128 {din[14]} n_5224 {din[14]} n_5320 {din[14]} n_5416
    -Bob
