  3. use of .fp.pg file
  • Subscribers 92
  • Views 13822
use of .fp.pg file
sambasiva
sambasiva over 14 years ago
 can Any body tell when  .fp.pg  file will get created and  the purpose of it.
  • BobD
    BobD over 14 years ago
    Thanks for this question.
    I did some research on this issue and it was tricky to create a situation where a .fp.pg file is created.  But I was able to eventually force one and I think it happens when you have
    Global net connections are typically defined and stored as follows...
    The first time you start a session you specify what the power and ground net names are on the Design Import form which in turn is saved in the .conf file:
    set rda_Input(ui_pwrnet) {VDD1 VDD2}
    set rda_Input(ui_gndnet) {VSS}
    Once the design is loaded, you establish global net connections via the globalNetConnect TCL command (or the GUI) which is then saved in the .fp file:
    GlobalNetConnection: VDD1 -pin VDD -inst * -type pgpin -all
    GlobalNetConnection: VSS -pin VSS -inst * -type pgpin -all
    Now, let's say you read in a DEF file that establishes connections that are different than what is in the .fp file.  For example one of the instances in the design has a VDD pin that's connected to VDD2 instead of VDD1:
    SPECIALNETS 3 ;
    - VSS  ( * VSS )
      + USE GROUND
    - VDD2  ( i_c/i0 VDD )
      + USE POWER
    - VDD1  ( i_b/i0 VDD )
      + USE POWER
    END SPECIALNETS
    The .fp file is now inconsistent with the DEF file.  When you do a "saveDesign -def" the tool saves both the .fp file and the .def file.  It uses this .fp.pg file to resolve inconsistencies between these two files.
    I hope that make sense and will help you troubleshoot the situation that gave rise to this question.
    Bob
