  3. Getting an xls file after generating the qor in RTL
  • Subscribers 92
  • Views 14263
Electronic Guy
Electronic Guy over 14 years ago
Is there any way to get an xls with all the qor reports of our syntheis in RTL compiler? In the DC using the dump_metrics command helps in creating an xls .. is there any way to do what in RTL compiler?
  • mclarke
    mclarke over 14 years ago
    Hi E. Guy,
       Yes RC has a very flexable and user configurable statistics capturing/reporting mechanism. Control is through the statistics command and a few statistics attributes. Multiple runs can be stored in the same db, then this db can be reload, compared or exported as text (for import to xls). The RC documentation covers the basic but contact me if you would like a working example.
    Cheers, Mike
  • Electronic Guy
     Hi Mike,
    Can you provide me with a working example please??
  • grasshopper
    grasshopper over 14 years ago
     Hi Electronic Guy,
     here is a quick example
    ## Optional Attributes
    set_attribute statistics_run_id statsdb_run /
    set_attribute statistics_run_description "This is a sample run of statsDB" /
    set_attribute statistics_db_file emac.stats_db /
    include lib_incl.tcl
    include ple_incl.tcl ;# This file is empty if no PLE was used
    include hdl_incl.tcl
    elaborate ${topDesign}
    if [file exists design.sdc] { read_sdc design.sdc }
    set sdcErrorFile [open ${runName}_error.info w]
    puts $sdcErrorFile $::dc::sdc_failed_commands
    close $sdcErrorFile
    ## User defined statsDB stage
    statistics log -stage_id constraints
    statistics write -to_file design.stats_db
    ##User defined metric
    #statistics add_metric -name effort_level -function get_effort_level
    #proc get_effort_level {} {get_attribute synthesize_effort_level /}
    synthesize -to_generic -effort low ${designName}
    synthesize -to_mapped -effort low -no_incr ${designName}
    ## Final report
    statistics report -run_id statsdb_run
    and this commands/attributes should be documented in the manuals as well
      hope this helps,
    gh-
  • mclarke
    Could you send youy contact info directly to mclarke@cadence.com. Since my email direct to you bounced.
