  3. A problem in ELC (Encounter Library Characterizer)
  • Subscribers 95
  • Views 14613
Hyunny
Hyunny over 14 years ago
Hi, I am characterizing standard cells, but I have the following problem. When I run db_spice, elc says "[WARNING(db_spice)]No spice simulation to do, please check the cell/process list for any error", and it does not do any simulation. Could anyone help me? My elccfg is EC_SIM_USE_LSF=1; EC_SIM_LSF_CMD=" "; EC_SIM_LSF_PARALLEL=2; EC_SIM_TYPE="hspice"; EC_SIM_NAME="hspice"; EC_SPICE_SIMPLIFY=1; EC_CHAR="ECSM-TIMING ECSM-POWER"; SUBCKT = "inv.sp"; MODEL = "tr_model.m"; DESIGNS = "INVX1"; SETUP = "mySetup"; PROCESS = "typical"; and inv.sp is .SUBCKT INVX1 A Z VDD VSS blah_blah..... (this section is too long, so I didn't show it) .ENDS Thank you.
  • wangweike
    wangweike over 14 years ago
    Hi, I think your problems must be in the subckt file,can you post it ?
  • Hyunny
    Hi, Thank you for your reply, but I finally resolved this issue. I thought that elc should work if I define Corner="typical" in a Process statement, Process MYP, and define Process="typical" in elccfg, but it was the problem. so I defined Corner="" in Process MYP, and defined Process="MYP" in elccfg, and it worked. Thanks, anyway!
  • jandark
    jandark over 13 years ago
     Hi frined
    I am going to calculate the characterization for some basic cell, I know I should survey time ,noise and power.
    but i don't know,how??
    I appreciate you if you help and guide me,
    Regards
  • great  ljx
    great ljx over 11 years ago
    hello ,
    can you explain this question more ,I try your way,but it doesn't work .
    I think I  must forget some thing ,so looking forword to your more detial about the question .
    3Q~
