  3. .cdb file used in SI analysis
  • Subscribers 92
  • Views 17059
vlsiproject
vlsiproject over 14 years ago
 I want to know about .cdb files which are used while performing SI analysis in Cadence encounter. Where i will get these files??
  • grasshopper
    grasshopper over 13 years ago
     Hi vlsiproject,
     please post to appropriate forums. RTL Compiler questions should go in the logic design forum. Encounter Design Implementation system should go in Digital Implementation forum. If anything previous posts in the forums should give you a good indication on whether or not you are posting to appropriate forum. Posting to the correct forum will expedite the answering of your questions. Also, please do let us know of any issues where documentation is confusing, insufficient or non-existent
     thanks,
    gh-
  • Kari
    Kari over 12 years ago
    for std cells, the vendor usually provides them. you can also try creating them yourself.
