  3. Encounter RTL-to-GDSII System 10.1 timing library inclu...
  • Subscribers 92
  • Views 13523
Encounter RTL-to-GDSII System 10.1 timing library include
vvijendr
vvijendr over 14 years ago
Hey, I am new to Digital Implementation. Where can I include common timing library file RTL-to-GDSII System 10.1. There was an option for this in SoC Encounter RTL-to-GDSII System 7.1 in Design Import. Could not find it in the new version. Also I would like to know how to do power analysis. Thanks, Vinay
  • Kari
    Kari over 14 years ago
     I believe that 10.1 has moved to using MMMC as the only way to bring in timing libraries. Check the User Guide for the chapter called
    Performing Multi-Mode Multi-Corner Timing Analysis and Optimization
    As for power analysis, that's a very general question. Start with the user guide, then post back if you still have questions.
