  3. No of Logic Levels in EDI
  • Subscribers 93
  • Views 13921
BhTeja
BhTeja over 14 years ago
Is there any command to find out No of Logic levels in EDI..
  • kazad
    kazad over 14 years ago
    Hi BhTeja
    I use the tcl procedure 'getLogicLevel' to extract the no. of logic levels from a given set of timing points. The procedures are embedded.
    Let me know if you have any issues with the procedure.
    Khandaker
    # Procedure to generate timing slack file
    # Usage: generateSlackReport -mode <setup | hold> -slackTarget <slack_target> -file <report_file>
    proc generateSlackReport {args} {
        # Defaults
        set slackTarget 0.0
        # Get setup/hold
        if {[regexp {\-mode} $args]} {
     set analysisMode [lindex $args [expr [lsearch $args -mode] + 1]]
        # Get slack target
        if {[regexp {\-slackTarget} $args]} {
     set slackTarget [lindex $args [expr [lsearch $args -slackTarget] + 1]]
        # Get slack file name
        if {[regexp {\-file} $args]} {
     set slackFile [lindex $args [expr [lsearch $args -file] + 1]]
        # Help
        set helpString "Usage : generateSlackReport \
                                    \-mode <setup | hold > \
                                    \-slackTarget <slack_target> \
                                    \-file <slack_file_name> \
                                    \-help"
        if {[regexp {\-help} $args] || $args == ""} {
     puts $helpString
     return 0
        # Main code
        # Open slack report file
        set f [open $slackFile w]
        # Set command set for setup/hold analysis
        if {$analysisMode == "setup"} {
     set rptTimingCmd {report_timing -from [all_registers -clock_pins] -to [all_registers -data_pins] -max_slack $slackTarget -late -collection}
        } elseif {$analysisMode == "hold"} {
     set rptTimingCmd {report_timing -from [all_registers -clock_pins] -to [all_registers -data_pins] -max_slack $slackTarget -early -collection}
        } else {
     puts "ERROR: Unsupported analysis mode!"
     return 0
        # Report header
        puts $f [genLine -width 100 -char "="]
        puts $f [format "%-10s %-8s %-8s %-25s %-50s %80s" "Slack" "Level" "Skew" "Clock Domain" "Launch Point" "Capture Point"]
        # Create a collection of timing paths
        set timingPaths [eval $rptTimingCmd]
        if {[sizeof_collection $timingPaths] > 0} {
     # Iterate over the set of paths, and process them one at-a-time
     foreach_in_collection path [sort_collection $timingPaths {slack}] {
         set timingPointsColl [get_property $path timing_points]
         set logicDepth [getLogicLevel $timingPointsColl]
         set startPoint     [get_property [get_property $path launching_point] hierarchical_name]
         set endPoint       [get_property [get_property $path capturing_point] hierarchical_name]
         set launchClock    [get_property [get_property $path launching_clock] hierarchical_name]
         set captureClock   [get_property [get_property $path capturing_clock] hierarchical_name]
         set launchClkEdge  [lindex [split [get_property $path launching_clock_open_edge_type] {}] 0]
         set captureClkEdge [lindex [split [get_property $path capturing_clock_close_edge_type] {}] 0]
         set launchClockTime [expr [get_property $path launching_clock_latency] + [get_property $path launching_clock_open_edge_time]]
         set captureClockTime [expr [get_property $path capturing_clock_latency] + [get_property $path capturing_clock_close_edge_time]]
         set skew [expr $captureClockTime - $launchClockTime]
         set slack          [get_property $path slack]
         puts $f [format "%-10s %-8s %-8.2f %-25s %-50s %-80s" $slack $logicDepth $skew "${launchClock}(${launchClkEdge})->${captureClock}(${captureClkEdge})" $startPoint $endPoint]
        close $f
    # Procedure to get logic level from a given collection of timing points
    proc getLogicLevel {timingPointsColl} {
        set currentInst ""
        set pathInstList {}
        foreach_in_collection timingPointObj $timingPointsColl {
     set pinObj [get_property $timingPointObj pin]
     set objType [get_property $pinObj object_type]
     if {$objType == "pin"} {
         set instObj [get_cell -of_objects $pinObj]
         set instName [get_property $instObj hierarchical_name]
     } else {
         set instName [get_property $pinObj hierarchical_name]
     if {$instName != $currentInst} {
         lappend pathInstList $instName
         set currentInst $instName
        set logicLevel [llength $pathInstList]
        return $logicLevel
    # Procedure to generate line seperator
    # Usage: genLine -width <width> -char <"character">
    proc genLine {args} {
        # Default
        set char "-"
        # Get width
        if {[regexp {\-width} $args]} {
            set width [lindex $args [expr [lsearch $args -width] + 1]]
        # Get char
        if {[regexp {\-char} $args]} {
            set char [lindex $args [expr [lsearch $args -char] + 1]]
        # Help
        set helpString "Usage : genLine -width <width> -char <character>"
     puts $helpString
     return 0
        # Main code
        for {set i 0} {$i <= $width} {incr i} {
     lappend print_list $char
        return "[join $print_list $char]"
  • BhTeja
    Thanks Kazad.  Its working .
