  3. point to point routing with specified routing length.
  • Subscribers 93
  • Views 15094
suresh84
suresh84 over 14 years ago
        can anyone please tell me how to route nets with specified length (say 100um) between 2 terms which are less than 100um apart using SOC Encounter.
suresh
  • kazad
    kazad over 14 years ago
    Hi Suresh
    The routing length can not be shorter than the manhattan length - you can check the manhattan length with the embedded procedure. By setting net attribute NR can be guided to make the routing as short as possible:
    setAttribute -net <net_name> -avoid_detour true
    # Procedure to report Manhattan length of a given net
    proc getManhattanLength {netName} {
        set first 1
        set netPtr [dbGetNetByName $netName]
        dbForEachNetTerm $netPtr termPtr {
            set termLoc [dbTermLoc $termPtr]
            set X [lindex $termLoc 0]
            set Y [lindex $termLoc 1]
            if { $first == 1 } {
                set min_x $X
                set max_x $X
                set min_y $Y
                set max_y $Y
                set first 0
            } else {
                if { $X < $min_x } { set min_x $X }
                if { $max_x < $X } { set max_x $X }
                if { $Y < $min_y } { set min_y $Y }
                if { $max_y < $Y } { set max_y $Y }
        set manhattan [expr (($max_x - $min_x) + ($max_y - $min_y)) * [dbHeadMicronPerDBU]]
        return $manhattan
    # Procedure to report routing length of a given net
    proc getNetLength {netName} {
        set wireLength 0
        if {$netPtr != "0x0"} {
            dbForEachNetWire $netPtr segmentPtr {
                set segLength [expr [dbWireLen $segmentPtr]*[dbHeadMicronPerDBU]]
                set wireLength [expr $wireLength + $segLength]
        return $wireLength
    Khandaker
  • suresh84
    Hi Khandaker,
                         Thanks for the reply. My case is to intentionally detour the route by specified length. The length is always greater than manhattan distance.
     Regards
    suresh
