  3. ELC not writing a .alf file
  • Subscribers 92
  • Views 13371
eklikeroomys
eklikeroomys over 14 years ago
Halo,
After the simulation of each cell, I get the following warning:
[WARNING(db_output)] Cannot output spec to ALF for cell A2A2O process typical
The .alf file that I get at the end is blank. What is causing this? If Im right the .alf is used by the tool to write the  .lib file, which is probably incorrect if the .alf is blank.
Is there some setting that I am missing?
Thank you
Chris
