  3. Exclude macros from addMetalFill
  • Subscribers 93
  • Views 13797
Johann Glaser
Johann Glaser over 14 years ago
Hi!
In my design there are two SRAM macros which should not be covered with metal fill. Although I've searched the documentation, forums and the internet, I didn't find a way to tell addMetalFill to exclude certain areas or macros. Could you please help me to find who to accomplish this?
  Hansi
  • icmaple
    icmaple over 14 years ago
    I also find nothing options to exclude Macro for adding metal fill.  i often create routing blockages over Macros.
  • Johann Glaser
    Hi again!
    After some playing I had the idea to remove the fillers from where I don't want them. Please find attached a section of the script doing this for a certain list of instances.
    # remove metal fill above certain instances
    set exclude_instances {core_1/TopAcchs_1/ram_interface core_1/TopAcchs_1/xram_interface}
    set offset 5.0
    foreach inst $exclude_instances {
      # use "eval" to get four individual parameters for iobox
      eval set box [dbGet [dbGetInstByName $inst].box]
      set x1 [lindex $box 0]
      set y1 [lindex $box 1]
      set x2 [lindex $box 2]
      set y2 [lindex $box 3]
      set x1 [expr $x1 - $offset]
      set y1 [expr $y1 - $offset]
      set x2 [expr $x2 + $offset]
      set y2 [expr $y2 + $offset]
      set area "$x1 $y1 $x2 $y2"
      puts "Removing metal fill for instance $inst in area $area"
      eval editDelete -shapes FILLWIRE -area $area
    Note that the editDelete instruction is sensitive to the preferences setting whether you want to delete "Enclosed by Box" or "Intersecting Box".
    Bye
      Hansi
