  3. Encounter Test run-time error
  • Subscribers 93
  • Views 13526
jamesASIC
jamesASIC over 14 years ago
 hi, I installed Encounter Test 9.1, and when I input "et", there's following error information:
 Error in startup script: no registered C procedure with name "fwAppQuery_calloutListIsAvailable_C"
    while executing
"method calloutListIsAvailable { project entity testmode experiment  failset callout } @fwAppQuery_calloutListIsAvailable_C"
    (class "fwAppQuery" body line 48)
    invoked from within
"itcl::class fwAppQuery {
  #   Public Definitions
    (file "/CAD/ET91/tools/tb/tcl/framework/fwAppQuery.itcl" line 42)
    invoked from within
"source $dir/fwAppQuery.itcl"
    (procedure "Framework_init" line 49)
    invoked from within
"Framework_init"
    (file "/CAD/ET91/tools/tb/tcl/framework/fwinit.tcl" line 135)
    invoked from within
"source /CAD/ET91/tools/tb/tcl/framework/fwinit.tcl"
    ("package ifneeded Framework 1.0" script)
    invoked from within
"package require Framework        "
    (file "/CAD/ET91.107/tools/tb/tcl/methodology/meth_cmds.tcl" line 320)
    invoked from within
"source /CAD/ET91/tools/tb/tcl/methodology/meth_cmds.tcl"
    ("package ifneeded Methodology 1.0" script)
    invoked from within
"package require Methodology"
    invoked from within
"if { [info exists env(Install_Dir)] } {
   ## Source GUI init file to setup auto_path (use TCL_PATH)
   foreach dir [split $env(TCL_PATH) :] {
    (file "/home/james/.testderc" line 2)
    invoked from within
"source $::env(TESTDE_RSRC)"
    (file "/CAD/ET91/tools/tb/tcl/main/guiMainForm.tcl" line 192)
linux version: Redhat 2.6.9;
ET version: 9.10.100
Thanks.
  • dft1
    dft1 over 14 years ago
     Hi James,
     It looks like you have an installation error.  How did you download the software?  Did you use get it from downloads.cadence.com?
    Also, why are you downloading ET 9.1.100?  That is pretty old and not supported.  You need to get ET 10.1.103.  If you still have issues with the installation, please contact support.cadence.com.
    And, by the way, ET 11.1.100 will be coming out in November.
    Thanks!
